Honda S2000 Honda S2000
Oil consumption problem
Old Sep 24, 2007 | 07:59 PM
RedstarS2K's Avatar
Default Oil consumption problem
Hi guys
im new in this forum and i really need your help. I put a new engine in my 2001 S2k ( 2500 miles after i buy it ) and it have only 21000 miles and seriously drink oil. I do a search and some people talk about krankvent. whats this thing? Is it really good to reduce oil cunsumption?
thanks in advance
Old Sep 25, 2007 | 04:03 AM
Miles69's Avatar
Default Re: Oil consumption problem (RedstarS2K)
Hi
Are you blowing smoke? Could be a bad piston ring or they never seated properly. Just a thought. Unless it's on the ground it has to be from the top end.
Old Sep 25, 2007 | 05:39 AM
RedstarS2K's Avatar
no, i see sometimes a little bit of smoke when i shift only. The engine perform great i think but smell oil consumption when i go over 6500 rpm.
Old Sep 26, 2007 | 10:16 AM
Black S2K's Avatar
damn could be your valve seals but they dont go bad untill you get mad miles on the motor. sorry cant really think of anyhting that will help besides a rebuilt head
Old Sep 26, 2007 | 05:28 PM
RedstarS2K's Avatar
ok, but if i put a krank vent, can it help or not?? I heard alot of good result about this but i dont want to buy that if its not useful.
Old Sep 26, 2007 | 07:03 PM
Black S2K's Avatar
Default Re: (RedstarS2K)
I have heard good things about the krank vent too but I dont have first hand experience with it so im not gona say if it will or wont
Old Sep 26, 2007 | 07:25 PM
RedstarS2K's Avatar
I try some product like oil treatment suppose to reduce oil consumption but nothing change. I think i will do a compression test, even if the engine have now only 23000 miles. The original engine of my car blow at only 41000 miles, but i never put oil in it after 2500 miles whit 10w40 castrol.
Old Sep 27, 2007 | 05:58 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
what color is the smoke???
if it has a blueish tint its oil....
what oil is in there? if its too thin you will burn oil.....
Old Sep 27, 2007 | 06:34 AM
composite guru's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedstarS2K &raquo;</TD></TR><TR><TD CLASS="quote">Hi guys
thanks in advance</TD></TR></TABLE>
Check all your breather pipes for blockages, this is one of the main reasons for heavy oil useage.
Old Sep 27, 2007 | 06:45 AM
RedstarS2K's Avatar
i see blue smoke only when i go over 8k rpm. But when the vtec engage i can smell something burning i dont know if its oil burning or only exhaust. I think its oil burning cause when i put a test pipe, the smell still the same.
I use Castrol 10w40 non-synthetic.
Old Sep 27, 2007 | 06:52 AM
RedstarS2K's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by composite guru &raquo;</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>are you talking abaout pcv? If not , what breathers pipes can i check? i never check anything like that in my other honda b-series.
Old Sep 27, 2007 | 09:57 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedstarS2K &raquo;</TD></TR><TR><TD CLASS="quote">are you talking abaout pcv? If not , what breathers pipes can i check? i never check anything like that in my other honda b-series.</TD></TR></TABLE>
The two pipes indicated on the pic are the main breathers, you will have to pull them off to check whether they are blocked. Flush them through with some brake cleaner or a cleaner of some sort. If you have a hard blockage you may need to use a piece of wire like a coat hanger or something.
Old Sep 27, 2007 | 01:42 PM
RedstarS2K's Avatar
Default Re: (composite guru)
ok. thanks for info and pictures .
I will try this. But can it possible that piston rings or the cylinders are in bad conditions?
Old Sep 27, 2007 | 02:01 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedstarS2K &raquo;</TD></TR><TR><TD CLASS="quote">ok. thanks for info and pictures .
I will try this. But can it possible that piston rings or the cylinders are in bad conditions?</TD></TR></TABLE>
No problem
I would find it hard to believe with that low mileage that the rings are shot, unless the car has had more miles than shown on the odo.
Christopher26
Mar 21, 2017 10:39 AM
down_the_hatch
Dec 6, 2015 09:59 PM
cjprelude
Mar 7, 2015 05:45 PM
r.etheridge
21
Feb 11, 2011 07:33 PM
