Honda S2000 Honda S2000
Oil consumption help
Old Jul 30, 2010 | 09:08 PM
bl1tzk1213g's Avatar
Default Oil consumption help
Well i've been burning oil and yes I know our cars tend to burn oil but mine's a little bit more than norm. I was thinking of the Supra PCV mod but is there a downside? I'm not running any boost. Oil catch can another choice?
Thanks!
Old Jul 31, 2010 | 06:09 AM
LaTe ApEx's Avatar
Default Re: Oil consumption help
How much oil are you using? What kind of oil are you using? What year/how many miles does your car have? Any signs of smoke?
Old Jul 31, 2010 | 07:51 AM
I recently did an oil change, 5quarts of mobile 1 5w30 with honda filter. I've put few miles on it and it's now below the middle on the dipstick. I'm not sure if the 5quarts was supposed to fill the whole dipstick but not its below the midline. I have roughly about 200,xxx no smoke im aware of
Old Jul 31, 2010 | 03:54 PM
LaTe ApEx's Avatar
Just keep an eye on it, check it every few days or so. All the x's combined on the dipstick equal one quart, so use that as a gauge. Im guessing you have an ap1. They are known to "eat" a little oil. 1 quart every 2000 miles or so is acceptable, maybe a little more with your mileage. If you have no other reason to suspect your engine is unhealthy I wouldn't worry about it. Also, imo mobil 1 is not the best choice for the f20c. Some cars consume it more than other brands of oil. If you are still worried about it when it comes time for your next oil change switch it up and try something else. I wouldn't change your pcv system, it probably won't help. Just make sure your pcv valve is good, I usually change mine with ever other oil change. Good Luck.
Old Jul 31, 2010 | 04:58 PM
any oil recommendation late apex? thanks for the reply
Old Aug 1, 2010 | 12:15 PM
LaTe ApEx's Avatar
Any of the major brand synthetics are good, castrol, pennzoil, valvoline, redline... etc. take your pick
I personally run amsoil 10w-30
Old Aug 1, 2010 | 04:05 PM
rxbahamut's Avatar
For higher mileage you can use conventional oil like Mobil 1 clean 5000 it helps with the burn off instead of synthetic. And go with maybe 10W40 or even if it is really bad go with 15w40 diesel oil I know diesel oil will clean better because they have more detergents. I don't think 15W40 will hurt the engine with tight clearances but ask here to find out too.
Old Aug 9, 2010 | 07:40 AM
Marrk's Avatar
Loved
Originally Posted by bl1tzk1213g
..... I'm not sure if the 5quarts was supposed to fill the whole dipstick but not its below the midline. ...
I don't know how you go about your oil changes, but I'm pretty thorough (read: ****) with mine, and I need to refill with almost 5.5 qts. on an oil change with filter. So, you may be closer to normal than you think.
Good luck.
Old Aug 9, 2010 | 12:51 PM
JulieU's Avatar
Now that you mention it, I think it's supposed to be 5.5 quarts (not 5 quarts).
Old Aug 9, 2010 | 12:58 PM
Marrk's Avatar
Loved
I think the book says 5.0 or 5.1, which is wrong and really screwed me up when I first got the car.
The reality is close to 5.5 on an oil change with filter.
Old Aug 12, 2010 | 08:02 PM
Ice78transam's Avatar
Hey Folks. Good to be back on the forum.
My experience has shown poor results using Mobil1 with honda VTEC motors. Used oil analysis showed that there was excessive wear. The wear was corrected by swithcing to Pennzoil platinum. I have found that Mobil1 reacts poorly to high rpm use (shearing) and very poorly to heat (Forced induction).
my .02 But please bear in mind that it's backed by much experience, and some cold science.
Additionally over-filling can pull oil through the PCV.
Good luck.
Old Aug 12, 2010 | 10:02 PM
JDMF22B's Avatar
Mobil 1 never touches my engine. I did once because I had to, then burned 1qt in 3k miles. I'm on 7k of Pennzoil platinum and not even half a quarts burned. Redline, Amsoil, Pennzoil, Eneos all great options
Old Aug 16, 2010 | 07:28 AM
White Smoke's Avatar
i my honda
Global Mod
Mobile 1 is not so great in the S2000, you will find that it burns up easily on high revving engines. Switch to another brand oil and I bet you notice a huge improvement.
This topic has been covered before, try out the sites search feature
Old Aug 16, 2010 | 09:00 AM
JulieU's Avatar
I recently switched from Mobil1 synthetic to AMSOIL 10w30. Unfortunately, I haven't noticed any significant improvements, i.e. I still have to add a half a quart every 3,000 miles or so.
I doubt this matters, but I also recently upgraded valve spring retainers/cotters to AP2, got a valve adjustment and replaced the PCV valve. My car is an early 2003 model (assembled in 2002). I think the next thing I'm gonna try is upgrading to an AP2 valve cover and PCV valve... see if that helps cut down on consumption.
Old Aug 16, 2010 | 10:52 AM
tmkpres's Avatar
This is true. I've always used castrol. I tried the moblie 1 cause everyone seemed to like it, but my car didn't, it seemed as though my car "DRANK" the mobile1.
Old Aug 16, 2010 | 08:11 PM
-=Zeqs=-'s Avatar
I thought the car calls for 10w30 anyways, unless you live in an area that gets well below freezing?
Old Aug 21, 2010 | 05:24 PM
davidc's Avatar
Take everbody's suggestions of oil brands with a grain of salt. There is no consensus here. Just check it regularly. Also, note that track days with high rpm's (or even street driving with high rpm's) will burn your oil much quicker.
Old Aug 21, 2010 | 08:27 PM
TOO MUCH TORQUE's Avatar
Try valvoline maxlife synthetic blend or full synthetic 10w-30. these are great burnoff oils. they are in the thicker 30 range but have fairly low noack numbers <--lower better for burnoff.
and m1 oils are hit or miss in engines. they can burn off quicker than normal or burn the same or less.
Old Aug 21, 2010 | 09:27 PM
davidc's Avatar
What's a great burnoff oil mean?
Old Aug 22, 2010 | 02:09 AM
less prone to being consumed or getting pass the oil control rings and then into the combustion chamber
RickSlick
Honda Fit
22
Feb 8, 2010 03:19 AM
HeDge_BB6
Jan 6, 2008 03:59 AM
digitalayon
Mar 13, 2005 07:55 AM
ironballz
May 13, 2004 02:38 PM
TypeR01-424
Aug 17, 2001 07:51 AM
