Honda S2000 Honda S2000
NeW BatterY!?
Old Feb 16, 2004 | 10:56 PM
Bs2kB6
Guest
Posts: n/a
Default NeW BatterY!?
well, i just ordered the hawker, Genesis (G16EP) Sealed Lead Acid Battery and wanted to know what some of you using this battery think of it and how you rate it. its 13.5 lbs so thats whats really making me happy right now LOL, anyways, i would like some feedback on the battery please and how long i should expect it to last and whether it will give me problems or not. weather wise, i live in southern cali so i dont think i'll be seeing 30 degrees and below. by the way, i am probably going to get an s2k in the near future/within the next 3-4 months and was wondering if this will fit in the s2k? i just ordered it for my prelude sh by the way. would it fit in the s2k or no?thanks guys. heres the link...
http://www.gotbatteries.com/Pr...dOn05
Old Feb 17, 2004 | 04:14 PM
evil vapor's Avatar
Default Re: NeW BatterY!? (Bs2kB6)
It'll work in the s2000. You wont have problems unless you plan to run amps and a large stereo system.
Old Feb 17, 2004 | 05:31 PM
DongTran's Avatar
be sure to get the metal jacket as the stock mounting location is near the exhaust manifold.
Old Feb 17, 2004 | 09:06 PM
evil vapor's Avatar
Default Re: (DongTran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DongTran &raquo;</TD></TR><TR><TD CLASS="quote">be sure to get the metal jacket as the stock mounting location is near the exhaust manifold. </TD></TR></TABLE>
The metal jacket isn't necessary, I'm not even running a header shield or battery shield. The extra $10 for the jacket is a waste unless the battery is exposed in an area directly next to heat or water or anything else corrosive.
Old Feb 17, 2004 | 09:25 PM
DongTran's Avatar
Default Re: (vapor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vapor &raquo;</TD></TR><TR><TD CLASS="quote">
The metal jacket isn't necessary, I'm not even running a header shield or battery shield. The extra $10 for the jacket is a waste unless the battery is exposed in an area directly next to heat or water or anything else corrosive. </TD></TR></TABLE>
Just like caps tire valve caps! Not necessary but an added level of protection :D Thanks for the insight!
Old Feb 17, 2004 | 10:09 PM
Bs2kB6
Guest
Posts: n/a
thanks guys. i appreciate the help so the size and specs will fit exactly to the s2k from my prelude?
Old Feb 17, 2004 | 11:04 PM
evil vapor's Avatar
Default Re: NeW BatterY!? (vapor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vapor &raquo;</TD></TR><TR><TD CLASS="quote">It'll work in the s2000. </TD></TR></TABLE>
Old Feb 18, 2004 | 12:48 PM
2K2 S2k's Avatar
The battery works great. I believe these batteries are the same (just re-branded). I have used one in my S2000 for almost a year so far and it has worked perfectly, even in 20 degree weather. I used a new aluminum clamp and modifed the plastic tray to secure the battery a little better, but it will work with stock battery retention parts.
Old Feb 18, 2004 | 03:57 PM
Heath's Avatar
Default Re: NeW BatterY!? (2K2 S2k)
What kinda modification we talking about? Just curious.
Old Feb 18, 2004 | 04:51 PM
2K2 S2k's Avatar
Default Re: NeW BatterY!? (95civicturbo)
I kept the stock plastic tray and added a flat piece of plastic about .200" thick that is a rectangle the size of the plastic tray with a rectangular cut out taken out of the center that is the size of the battery. This basically locates the battery on all four sides at the bottom so it can't move fore and aft or side to side. Probably overkill but simple and effective.
Old Feb 18, 2004 | 09:49 PM
Bs2kB6
Guest
Posts: n/a
hey, what year s2k has that S emblem? is it the 03's?
Old Feb 19, 2004 | 06:22 AM
DongTran's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bs2kB6 &raquo;</TD></TR><TR><TD CLASS="quote">hey, what year s2k has that S emblem? is it the 03's?</TD></TR></TABLE>
You talking about this?
It doens't come stock on S2000s. You can buy them from http://www.ricks2k.com
He's good good customer service. The "S" badges are not my cup of tea personally...
Old Feb 19, 2004 | 12:38 PM
Bs2kB6
Guest
Posts: n/a
Default Re: NeW BatterY!? (DongTran)
ohhh ok, thanks a lot man.
Old Feb 19, 2004 | 03:35 PM
skafia's Avatar
25 Year Member
Those S emblems are ghey...
BlackThorN
Audio / Security / Video
15
Jun 27, 2004 01:31 PM
Bs2kB6
Honda S2000
Feb 23, 2004 06:31 PM
Bs2kB6
Feb 18, 2004 07:10 AM
tC_Dragon
Feb 23, 2003 02:36 AM
JDubya
Apr 30, 2002 01:33 PM
