Honda S2000 Honda S2000
Misfire codes
Old Mar 28, 2008 | 07:22 AM
marineway's Avatar
Default Misfire codes
Keep getting P0301 misfire cylinder 1 code. Have changed, plug, coil and PCV. Based on what I've read earlier, I guess this means I need a valve adjustment...but why on only one cylinder? Comments?
Old Mar 28, 2008 | 07:50 AM
joey1320's Avatar
Default Re: Misfire codes (marineway)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marineway &raquo;</TD></TR><TR><TD CLASS="quote">Keep getting P0301 misfire cylinder 1 code. Have changed, plug, coil and PCV. Based on what I've read earlier, I guess this means I need a valve adjustment...but why on only one cylinder? Comments?</TD></TR></TABLE>
first do a dompression test and a leakdown test. this engine should have upqwards of 230psi per cylinder. see what your compression is and go from there. it may need a valve adjustment, valves, valve guides, valve seats, piston rings etc.
so don't think is only a valve adjustment issue, that's one of many causes of misfires. good luck and keep us updated!
Old Mar 28, 2008 | 10:01 AM
ntensehonda's Avatar
Possible cracked retainer not closing the valve all the way?
Old Mar 31, 2008 | 07:36 AM
j spec's Avatar
Default Re: Misfire codes (ntensehonda)
how many miles on car?
what model is it?
Old Mar 31, 2008 | 09:38 AM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: Misfire codes (j spec)
could also be an injector issue
Old Mar 31, 2008 | 10:25 AM
Fe Le Fa La's Avatar
* B A N N E D *
Default Re: Misfire codes (GRAF-FITI)
Blow **** Say something meaningful please!!!
Old Mar 31, 2008 | 10:30 AM
joey1320's Avatar
Default Re: Misfire codes (Fe Le Fa La)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fe Le Fa La &raquo;</TD></TR><TR><TD CLASS="quote">Blow **** Say something meaningful please!!! </TD></TR></TABLE>
great way to start posting u noob... why don't you add anything meaningful ???
anyways, marineway, any updates on this problem?
Old Mar 31, 2008 | 10:54 AM
megalomaniac001's Avatar
Default Re: Misfire codes (joey1320)
i had the misfire code once. I got some bad or old or something in my gas when I filled up once. I thought a misfire code in all 4 cylinders and the multiple misfire code too. I had to drain my tank, clear the codes and I haven't seem them since.
Old Mar 31, 2008 | 11:11 AM
GRAF-FITI's Avatar
* B A N N E D *
hahaha again I OWN YOU rookie
Old Mar 31, 2008 | 11:30 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
dude you still havent said anything meaningful... get the **** outta here...
when u changed everything out, did u reset the ecu?
swap out the #1 with everything from the #2, 3, or 4 and then reset the ecu... then see if its #1 still... if it changed then its something correlated with whatever u swapped out from #1... then u can narrow down whats causing the misfire...
Old Mar 31, 2008 | 11:32 AM
S2KILLA's Avatar
Default Re: Misfire codes (S2KILLA)
ohhh and marine... i go down to Stuart once a year to visit a friend of mine... we usually go to Jensen Beach while were down there...
Bare Bones is the **** btw...
Old Mar 31, 2008 | 11:39 AM
marineway's Avatar
Joe- After spending 23 years flying A-6s and F/A-18 in the Marines, I hardly need an adolescent like you to lecture me about "some people rather dying than thinking". I've gotten some actual assistance from some of the less childish posters, which I appreciate. Beyond this e-mail, your need to feel superior by denigrating new posters to this thread will not be read, or respponded to by me.
LtCol Al Pavsner USMC (Ret)
Old Mar 31, 2008 | 11:47 AM
S2KILLA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marineway &raquo;</TD></TR><TR><TD CLASS="quote">Joe- After spending 23 years flying A-6s and F/A-18 in the Marines, I hardly need an adolescent like you to lecture me about "some people rather dying than thinking". I've gotten some actual assistance from some of the less childish posters, which I appreciate. Beyond this e-mail, your need to feel superior by denigrating new posters to this thread will not be read, or respponded to by me.
LtCol Al Pavsner USMC (Ret)</TD></TR></TABLE>
huh?
who the hell wrote that?
Old Mar 31, 2008 | 11:53 AM
GRAF-FITI's Avatar
* B A N N E D *
hahahahahaha WTF
you uneducated idiot this isn't an email
joey&gt;you
Old Mar 31, 2008 | 11:55 AM
bigmacnfries's Avatar
that "dying rather than thinking" thing is in his signature - i.e. it is a generic comment that crops up with every post of his. Not directed at you.
Old Mar 31, 2008 | 11:56 AM
I spent 3 months flying Cessna's, but i didn't get any letters before or after my name? WTF?
Old Mar 31, 2008 | 01:28 PM
joey1320's Avatar
muaahahahahahaahahahahahaha... haha i feel like graf
wow that was weird...
couple of things LtCol Al Pavsner USMC (Ret):
1: this is not an email, this is a post responding on the thread you started.
2: the "some people rather..." quote is my signature, like the one that everyone has on their posts. is actually from one of my favorites books by Gabriel Garcia Marquez, and i wasn't talking about you so don't get your panties all wet...
3: i could care less what you did, do or will do with your personal life, but please, before you ridicule yourself anylonger, try to learn what a forum is and how it works. i.e you start a thread with a question and i answer on a post.
anyways, did you get something fixed or what?
and btw i'm one of the nice guys here
Modified by joey1320 at 10:36 PM 3/31/2008
Modified by joey1320 at 10:44 PM 3/31/2008
Old Mar 31, 2008 | 01:41 PM
joey1320's Avatar
wait wtf??? how did my first post didn't help you? i gave you a simple outline to follow regarding the compression requirements for this engine.
do you even know how to do a compression test, or are you still thinking about carburetors and points timin'? sorry i'm really not trying to be an *** but you jumped to a conclussion before having any idea wtf you were talking about...
Old Mar 31, 2008 | 01:57 PM
GRAF-FITI's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joey1320 &raquo;</TD></TR><TR><TD CLASS="quote">
interesting when you see things from my point of view, hey?
Old Mar 31, 2008 | 02:24 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAF-FITI &raquo;</TD></TR><TR><TD CLASS="quote">
interesting when you see things from my point of view, hey? </TD></TR></TABLE>
i think he meant he was playing with himself at the time, and it reminded him of the days when you two were together...
Old Mar 31, 2008 | 02:32 PM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: Misfire codes (bigmacnfries)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigmacnfries &raquo;</TD></TR><TR><TD CLASS="quote">
i think he meant he was playing with himself at the time, and it reminded him of the days when you two were together... </TD></TR></TABLE>
whats funny though is you're known as "the man from down under"...not because of your location.....
8::::::::::::D
Old Mar 31, 2008 | 02:46 PM
8::::::::::::D </TD></TR></TABLE>
that's cos most of the women round here say: "I'm busy at the moment, cos i've got a man down under"
plus you were missing a couple of :::'s
Old Mar 31, 2008 | 02:50 PM
GRAF-FITI's Avatar
* B A N N E D *
plus you were missing a couple of :::'s</TD></TR></TABLE>
i would rethink what you just typed
Old Mar 31, 2008 | 03:26 PM
i don't do re thinking. thinking is enough for me.
Old Mar 31, 2008 | 03:30 PM
joey1320's Avatar
yeah kinda [freak]ed up
back at cha!
