Honda S2000 Honda S2000
LIST of CEL codes?
Old Jul 17, 2007 | 02:50 PM
veilsides2000's Avatar
Default LIST of CEL codes?
Hello, Does anybody happen to know where i can get a list of CEL codes for a 2002 honda s2000.
I got into an accident two weeks ago and my whole left wheel and sussy was gone. Now my Power steering doesnt work and a check engine light is on. I jsut got the car back from the shop right now.
The car runs great! and i tried the battery disconnecting trick but it comes back on. ANy help would be greatly appreciated!
Old Jul 17, 2007 | 02:58 PM
Default Re: LIST of CEL codes? (veilsides2000)
and by the way. The car doesnt make that whining noise naymore either when you first start it. And that is when the CEL comes on. Does that have anything to do with my power steering?
Old Jul 17, 2007 | 04:29 PM
nobody?
Old Jul 17, 2007 | 05:17 PM
LemurFaktore's Avatar
your best best, find someone who has a scanner...
easier that way...hook up the scanner, pull codes, ck actual values, try actuations, n repl. whatever it is....pullin codes w/o a scanner is old school
Old Jul 17, 2007 | 10:00 PM
Default Re: (LemurFaktore)
I pulled the code and it said it was P0141. "heatsensor" or something. Anybody know what that is?
That was the only code.
The engine runs perfect. and vtec engages fine. NO problems with overheating or anthing.
Old Jul 18, 2007 | 05:24 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
Default Re: (veilsides2000)
http://www.s2ki.com/forums/ind...90537
Old Jul 18, 2007 | 05:32 AM
S2KILLA's Avatar
Default Re: (S2KILLA)
basically buy a new O2 sensor, replace the bad one, and be on your way... is it still under warranty?
Old Jul 18, 2007 | 06:57 AM
na its an 02. Its not under warranty.
I was reading your link above and the user in there says something about the secondary one being "IN" the CATHYLIC COnverter? Im a little confused at this.
thanks again
Old Jul 18, 2007 | 08:57 AM
S2KILLA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by veilsides2000 &raquo;</TD></TR><TR><TD CLASS="quote">na its an 02. Its not under warranty.
thanks again</TD></TR></TABLE>
haha he must be really religeous... hahaha jk, i know u meant to say catalytic... ok theres two(2) O2 sensors... one that screws in the header and one that screws into the Cat... the one in the cat is the one thats bad... my advice to u is to do a visual first... jack the car up, put stands for added safety... unscrew the sensor, look at it, see if its melted or got a lot of build up on it... clean it off if it does, reinstall, reset ecu... and see if it throws it again... if the O2 sensor looks f'ed unclip it, go to the store, buy a new one and clip it back it... should be easy enough... its not a hard thing to do but just a pain in the ***... good luck and reply if u have any more ?'s
Old Jul 18, 2007 | 11:15 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2KILLA &raquo;</TD></TR><TR><TD CLASS="quote">
haha he must be reallyreligeous ... hahaha jk, i know u meant to say catalytic... ok theres two(2) O2 sensors... one that screws in the header and one that screws into the Cat... the one in the cat is the one thats bad... my advice to u is to do a visual first... jack the car up, put stands for added safety... unscrew the sensor, look at it, see if its melted or got a lot of build up on it... clean it off if it does, reinstall, reset ecu... and see if it throws it again... if the O2 sensor looks f'ed unclip it, go to the store, buy a new one and clip it back it... should be easy enough... its not a hard thing to do but just a pain in the ***... good luck and reply if u have any more ?'s</TD></TR></TABLE>
Lol I know you meant to say religous... Im just messing with yaman.
Im going to raise the car up and inspect it. Thanks for the help!!
Old Jul 19, 2007 | 09:42 AM
Mr. Projekt's Avatar
* B A N N E D *
Buy a Helms manual.
As far as your power steering, check the EPS fuse box, then the rack itself.
crxowner
Oct 12, 2011 02:54 PM
music462
Apr 10, 2008 05:37 AM
Parada
Mar 9, 2007 05:02 PM
