Honda S2000 Honda S2000
launch 2002 s2000
Old Apr 29, 2007 | 09:52 AM
mark31kiss's Avatar
Default launch 2002 s2000
i have a stock s2000 2002 and i was wondering what i should launch at?????????
Old Apr 29, 2007 | 10:05 AM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: launch 2002 s2000 (mark31kiss)
You need a runway, because if you try to launch this car it will go into outer space.
Old Apr 29, 2007 | 10:06 AM
LAS2K's Avatar
6500rpm. feather clutch.
worked for me when i used to abuse her.
b20integrapower's Avatar
I wouldn't. Unless you want to be replacing your diff any time soon.
Old Apr 29, 2007 | 10:07 AM
WowOzYouRock's Avatar
it depends what tires... you hafta let the back loss so you wont break your diff...
and you gonna lose regardless... s2000 suck in straight line unless its boosted..
Old Apr 29, 2007 | 10:08 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: launch 2002 s2000 (FR-MOB: Jerk)
7K play the clutch!
mark31kiss's Avatar
damn 6,500 sounds cool ill try it out
Old Apr 29, 2007 | 10:10 AM
Default Re: (mark31kiss)
^^^ ROFL ...
Old Apr 29, 2007 | 10:25 AM
* B A N N E D *
Default Re:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mark31kiss &raquo;</TD></TR><TR><TD CLASS="quote">damn 6,500 sounds cool ill try it out</TD></TR></TABLE>
Broken diff thread within 1 month.
Old Apr 29, 2007 | 10:54 AM
Default Re: Re: (Mr. Projekt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Projekt &raquo;</TD></TR><TR><TD CLASS="quote">
Broken diff thread within 1 month.</TD></TR></TABLE>
i second this.
Old Apr 29, 2007 | 11:46 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: Re: (b20integrapower)
as long as u do it right the rear end will hold.. **** MINE did for a year anda half....
Old Apr 29, 2007 | 11:49 AM
S2F20's Avatar
6500 would be the best.....
Old Apr 29, 2007 | 04:21 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (S2F20)
1.9 60 FT here with 7K.... tried 6500 and was going 2.0's...
Old Apr 30, 2007 | 06:32 AM
Lsos's Avatar
So when exactly does the differential tend to break? When you drop the clutch?
Old Apr 30, 2007 | 10:14 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: launch 2002 s2000 (Lsos)
there is no breaking point but it comes from abused and its limit what it can handle
Old Apr 30, 2007 | 11:32 AM
Francesco's Avatar
rofl.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20integrapower &raquo;</TD></TR><TR><TD CLASS="quote">
i second this.</TD></TR></TABLE>
I 3rd it
Old May 2, 2007 | 04:31 AM
prr1's Avatar
Launch at 7k and feather the clutch. Your diff will be fine. All of these passes were on a stock diff and stock clutch with 86,xxx miles on both.
9.5psi S2000 vs C6
Click here to see Video
9.5psi S2000 vs Nitrous T/A
9.5psi S2000 vs S2000
Old May 2, 2007 | 06:06 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: launch 2002 s2000 (prr1)
^..... AP1 FTMFW
Old May 2, 2007 | 07:40 AM
TommyV's Avatar
I suppose you'll be posting again soon asking why your diff isn't covered under warranty.
Old May 2, 2007 | 07:51 AM
Damon Reeves's Avatar
Old May 2, 2007 | 09:26 AM
Phil DeVtec's Avatar
Default Re: launch 2002 s2000 (Damon Reeves)
It's all about clutch work when launching. S2Ks are easy compared to trying to launch an AWD car. Feather the clutch.
Old May 2, 2007 | 09:41 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: launch 2002 s2000 (Phil DeVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phil DeVtec &raquo;</TD></TR><TR><TD CLASS="quote">It's all about clutch work when launching. S2Ks are easy compared to trying to launch an AWD car. Feather the clutch. </TD></TR></TABLE>
correct... play the clutch right and your diff will be saved!
Old May 2, 2007 | 10:11 AM
ReddotsS2K's Avatar
Default Re: launch 2002 s2000 (S@nt0s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S@nt0s &raquo;</TD></TR><TR><TD CLASS="quote">
correct... play the clutch right and your diff will be saved! </TD></TR></TABLE>
and if you cant use a clutch right then stick to automatics
the problem for me was tires. the tires on my car are ****. with working the clutch right and some good tires, its money.
Old May 2, 2007 | 10:55 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: launch 2002 s2000 (ReddotsS2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReddotsS2K &raquo;</TD></TR><TR><TD CLASS="quote">
yes and no... love bangin gears, but autos can get it done too!
Old May 2, 2007 | 11:05 AM
^^ i only love bangin pu-nan-ni.. rofl
