Honda S2000 Honda S2000
How to launch your S2000
Old Oct 17, 2003 | 11:53 PM
White S2k's Avatar
Default How to launch your S2000
I went to the track the other week for the first time and came across a problem when launching my s2000. No matter what RPM i drop the clutch at, the rpm will bog down for a second and then start to raise. Even on the street from a stand still i would try this and notice it does this everytime. Is there a traction control on the S2000, and if so can it be taken off by a fuse? If not what is the best way that you guys have come accross to launch it?
Old Oct 18, 2003 | 02:40 AM
TommyV's Avatar
Default Re: How to launch your S2000 (White S2k)
There is no defeatable traction control in the S2000s.
Not sure why you are having issues "burning out" in your S......
Old Oct 18, 2003 | 03:14 AM
evilf20c's Avatar
I usually tach it up to 4500 then let off the clutch real fast and I have no problems. That is during cold rubber but when they are already hot I launch way higher.
Old Oct 18, 2003 | 09:49 PM
Mr. Bagel's Avatar
there is no traction control in this car. the traction problem and gas problem you are experiencing is between the seat and the steering wheel.
here's the best way to launch it: 7500rpm clutch drop! yeup, that's the way to do it. but please, don't come back crying when your entire diff needs to be replaced.
Old Oct 18, 2003 | 10:36 PM
slowsh's Avatar
Default Re: How to launch your S2000 (Mr. Bagel)
the sweet spot seems to be at 5200, but this will depend on tire condition. but for a new set of tire 5200 seem to be it
Old Oct 20, 2003 | 01:39 AM
Gerhard_001's Avatar
Well this is known as bogging. This is a VTEC car you need to launch high 5500-6000rpm is optimum for these cars on street tires, drag radial 7000-8000rpm, full slicks 8300 and higher and bye bye clutch. there is no traction control and no fuse you can take out to magically make you a better driver, Befor asking questions like that assess your own driving skill.
Old Oct 20, 2003 | 08:19 AM
jolt-tsp's Avatar
Default Re: How to launch your S2000 (Gerhard_001)
It's gonna depend on your tires. If you're bogging go higher, if you're burning go lower. On the stock s-02's 5-6k is normally pretty good depending on the wear.
Old Oct 20, 2003 | 08:46 AM
Muckman's Avatar
Moderator in Chief
My friend used to dump his S2000 at 7 or 8k inorder to break the rear wheels loose at the track. He managed a best of 14.0 on a stock S2000.
Old Oct 20, 2003 | 12:03 PM
White S2k's Avatar
Thanks for the opinions. So im getting that dropping it around 5-6 is the key
Old Oct 20, 2003 | 07:07 PM
Channinator's Avatar
my mom has one and when i get the chance to drive it.........i normally drop it at 9k hahaha.......man im mean. i just wish it was mine.
Old Oct 20, 2003 | 07:52 PM
Razor's Avatar
Default Re: (Channinator)
END YOURSELF
Old Oct 20, 2003 | 07:58 PM
Mase's Avatar
Default Re: (Razor)
Yes, this topic is always covered, the search feature works great, I promise.
Old Oct 21, 2003 | 03:53 AM
Mocky57's Avatar
Default Re: (Mase)
personally, i can't imagine doing any sort of high rpm drop (and cook the tires).
i don't know about everyone else, but everytime I tear up the tires, I smell money burning (well, the tires too).
8k of daily driving and tire replacement gets old pretty quick (good friend's wife went with S-03's and didn't get 10k either).
oh well, the price to pay for fun
Old Oct 22, 2003 | 09:51 PM
Jawad.'s Avatar
Default Re: (Razor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Razor &raquo;</TD></TR><TR><TD CLASS="quote">END YOURSELF</TD></TR></TABLE>
Bahahahah!!
what a fucked up son !
Old Oct 22, 2003 | 10:53 PM
evil vapor's Avatar
Default Re: (Mase)
If you want your car to last, don't dump the clutch, don't speed shift, don't launch the car. The drivetrain cannot handle shock well. If you want to launch, at least load the powertrain to minimize shock. There is a weak clutch in this car from the factory for a reason.
Old Jan 14, 2004 | 07:33 AM
mooboygsr's Avatar
Default Re: (vapor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vapor &raquo;</TD></TR><TR><TD CLASS="quote">If you want your car to last, don't dump the clutch, don't speed shift, don't launch the car. The drivetrain cannot handle shock well. If you want to launch, at least load the powertrain to minimize shock. There is a weak clutch in this car from the factory for a reason. </TD></TR></TABLE>
What reason is that?
Old Jan 14, 2004 | 07:41 AM
Razor's Avatar
Default Re: (mooboygsr)
too put less shock on the rest of the drivetrain(especially the diff).
Old Jan 14, 2004 | 08:29 AM
Bs2kB6
Guest
Posts: n/a
Default Re: (Razor)
how much is it to get strong diff.? or whatever else is needed for the car to not fall apart of launch? meaning the problem the s2k has with launching.
Old Jan 14, 2004 | 09:08 AM
Project SSAP1's Avatar
Default Re: (Bs2kB6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bs2kB6 &raquo;</TD></TR><TR><TD CLASS="quote">how much is it to get strong diff.? or whatever else is needed for the car to not fall apart of launch? meaning the problem the s2k has with launching.</TD></TR></TABLE>
go here.... http://www.ricks2k.com/products/Comptechdiff.php
while u ar at it get an upgraded final drive (ricks 4.56 will do nicely) and pressure plate.. i def would not use the s2k to drag race and luanch the car at high rpms..the clutch i feel is very weak and cant take the abuse of high rpm launch all the time..plus its so damn expensive to buy new parts..
Old Jan 14, 2004 | 01:55 PM
Bs2kB6
Guest
Posts: n/a
Default Re: (Project SSAP1)
if i were to get that diff. reinforcement thing, won't it be ok to launch the car often? and what about the 4.77 final drive? or no? by the way, you said the clutch is weak, so wouldn't that be when i get a stronger clutch. it wouldn't be weak anymore would it. also, do ppl change the final drive because the gears are long on the s2k? someone said 1st gears ends around 50mph? and what is the 0-60 on the car? 5.5? if i were to change the final drive would it improve my 1/4 and 0-60 as well as lower speed at 1st gear?
Old Jan 14, 2004 | 02:00 PM
LSHatch's Avatar
When I ran my car at the track, I was launching between 7-7.2k and slipping the clutch hard to keep it in vtec. I ran a 13.7 with that technique.
Try whatever works best for you.
Old Jan 14, 2004 | 08:20 PM
OC 335i's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Project SSAP1 &raquo;</TD></TR><TR><TD CLASS="quote">while u ar at it get an upgraded final drive (ricks 4.56 will do nicely) and pressure plate.. i def would not use the s2k to drag race and luanch the car at high rpms..the clutch i feel is very weak and cant take the abuse of high rpm launch all the time..plus its so damn expensive to buy new parts.. </TD></TR></TABLE>
I have read on s2ki some people do launch at high rpms and the clutch does not seem to be a problem and holds up.
There are people with stock clutches with superchargers. It really depends on how you drive though.
Old Jan 14, 2004 | 10:03 PM
CleenSi
Guest
Posts: n/a
Default Re: How to launch your S2000 (TommyV)
i dont own an S2000, but ive heard from people at the strip that they like to launch at 6k when tires are warm...
hope this helps
Old Jan 17, 2004 | 08:26 AM
JSPECEX's Avatar
Default Re: How to launch your S2000 (CleenSi)
what ever happened to feathering the clutch i think thats is his biggest problem and why he is bogging . take it to like 4500-5000 and slowly let out the clutch and feel the the car and adjust clutch and gas so the you are constintly accelerating
Old Jan 18, 2004 | 06:11 AM
Speedra500's Avatar
Default Re: How to launch your S2000 (JSPECEX)
I agree, thats how i launch, around 5.5k feathering the clutch on street tires
