Honda S2000 Honda S2000
HELP water problem!!!!!!!!!!!!!!!!!!!!!
Old May 20, 2007 | 07:15 PM
DALLEN's Avatar
Default HELP water problem!!!!!!!!!!!!!!!!!!!!!
ok so the rain started coming down like crazy and i went to pick up a friend from his house. when i approched a puddle that looked harmless enough, as other cars were driving through it no problem. when i tried to drive through i sucked water through my cold air intake:banghead: :banghead: :banghead: now here's my issue how do i go about getting it out of my engine and is there going to be any long term effcts please help thanks
-Dallen
Old May 20, 2007 | 08:15 PM
m R g S r's Avatar
Default Re: HELP water problem!!!!!!!!!!!!!!!!!!!!! (DALLEN)
you know you can't compress water right?
when your piston tries to compress it, the weakest link will most likely be the rod and it will snap....it happened to me on my integra sucked a lotttt of h20 through my gt32e lol
bye byeee rod....went right through the side of the block!
Old May 20, 2007 | 09:15 PM
s2kdre's Avatar
Default Re: HELP water problem!!!!!!!!!!!!!!!!!!!!! (m R g S r)
if u were ideling when it stalled then most likely ur ok, but i hope u didnt try to start it.
Old May 21, 2007 | 10:43 AM
DALLEN's Avatar
Default Re: HELP water problem!!!!!!!!!!!!!!!!!!!!! (s2kdre)
no i didn't try to start it i was rolled up to an intersection so i was going really slow almost idle i had it towed to my house took out the spark plugs cranked it by hand a few time can here water in there aswell i'm goin to have it towed to the dealership tomorrow i dont have the tools and things to fix it at my house as i'm only living here temperarily..........is this going to be expensive??
Old May 21, 2007 | 10:48 AM
Mr. Projekt's Avatar
* B A N N E D *
If you did what you said you did which is:
1) Did not start the motor immediately after.
2) Moved the car to a safe place by other means
3) Pulled all the plugs and cranked the motor.
Your next step is to get a compression and leakdown test, done by someone with know-how. The result will determine what comes next.
Old May 22, 2007 | 10:39 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: HELP water problem!!!!!!!!!!!!!!!!!!!!! (Mr. Projekt)
yes as stated above, pull the plugs and let it dry out... if you can stick a vac in there in any way to that also cranking it over will help ( without plugs)
Old May 22, 2007 | 11:29 AM
Cboi's Avatar
and put stock airbox back on instead of ur cold air intake when u take it to dealer
mozzandherb
Dec 16, 2007 10:53 PM
Liquid Ice NF
Aug 12, 2005 05:52 PM
mikael
Jan 10, 2005 05:56 PM
leftymo
Dec 28, 2004 12:02 PM
