Honda S2000 Honda S2000
Help I Have a Problem!
Old Dec 13, 2005 | 12:32 PM
socals2k's Avatar
Default Help I Have a Problem!
I was changing my oil this morning when i noticed this dangling in my engine bay dangerously close to my pullies....what is it? Where does it go? and what does it do? anyone else had issues with this?
I labled it the best i could, bad pic cause i had to use my phone....
thanks for all your input....mason
So i guess i can't upload....so here is a link...sorry...
http://mperry673.photosite.com/Album1/dangle.html
http://mperry673.photosite.com....html
Modified by socals2k at 2:20 PM 12/13/2005
Old Dec 13, 2005 | 12:34 PM
hypnosisracing's Avatar
Default Re: Help I Have a Problem! (socals2k)
I'd deffinately have those red X's checked...cant be good for the drivetrain.
Old Dec 13, 2005 | 12:38 PM
WowOzYouRock's Avatar
Default Re: Help I Have a Problem! (hypnosisracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hypnosisracing &raquo;</TD></TR><TR><TD CLASS="quote">I'd deffinately have those red X's checked...cant be good for the drivetrain.</TD></TR></TABLE>
i concur
Old Dec 13, 2005 | 12:54 PM
socals2k's Avatar
put in a link instead of red x's
oh btw the red x's add 12hp each, i know where to get them really cheap too
Old Dec 13, 2005 | 12:59 PM
Dont feel like registering for that site...wont let you view any other way.
Old Dec 13, 2005 | 01:02 PM
socals2k's Avatar
expletive!!!
Old Dec 13, 2005 | 01:18 PM
socals2k's Avatar
17th time is the charm....thanks for your patients...
Old Dec 13, 2005 | 01:37 PM
SteveoBA8's Avatar
Default Re: (socals2k)
Baro sensor? Just mount it somewhere, there should be threads where it was once bolted too close to it.
Old Dec 13, 2005 | 01:42 PM
Default Re: (SteveoBA8)
just zip tie that ish
Old Dec 13, 2005 | 03:31 PM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: (Y2K_S2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Y2K_S2K &raquo;</TD></TR><TR><TD CLASS="quote">just zip tie that ish </TD></TR></TABLE>
.. to your intake. If you have the stock one there's a screw hole for it.
Old Dec 13, 2005 | 09:20 PM
jimbonuttz's Avatar
there intake/vacum sesnors usually it bolts up to your intake box but if you replaced that then youll have to find an alternative place to mount it...
Old Dec 13, 2005 | 09:32 PM
revvin9k's Avatar
Default Re: (jimbonuttz)
Before you zip tie anything, clean your damn bay.
That's terrible.
Old Dec 13, 2005 | 10:19 PM
ej0513's Avatar
zip tie it to the belt.. itll get rid of your problem.
Old Dec 14, 2005 | 05:11 PM
littleredhatch's Avatar
Default Re: (ej0513)
evap purge soleniod
Old Dec 15, 2005 | 07:55 AM
LBBP R's Avatar
Default Re: (littleredhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by littleredhatch &raquo;</TD></TR><TR><TD CLASS="quote">evap purge soleniod</TD></TR></TABLE>
y is it hanging all the way down there??? it should be back of your stock intake box.. unless you have after market intake..
Old Dec 15, 2005 | 07:59 AM
* B A N N E D *
Default Re: (LBBP R)
back?
theres a hole in the front cross beam to zip tie through.. though the AEM has a tab you can tie it to also.
Old Dec 15, 2005 | 08:00 AM
Nishant's Avatar
Default Re: (Slideways2000)
the aem does have a built in tab, its on the underside of the peice that connect to the throttle body
Old Dec 15, 2005 | 08:10 AM
LBBP R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slideways2000 &raquo;</TD></TR><TR><TD CLASS="quote">back?
theres a hole in the front cross beam to zip tie through.. though the AEM has a tab you can tie it to also.</TD></TR></TABLE>
oppss... confused.... yea, it's behind the cross-beam.. hehehe
Old Dec 15, 2005 | 08:28 AM
Newkdog's Avatar
I miss Andrea.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SteveoBA8 &raquo;</TD></TR><TR><TD CLASS="quote">Baro sensor? Just mount it somewhere, there should be threads where it was once bolted too close to it.</TD></TR></TABLE>
You stole MSchu's avatar, better get a new one buddy.
cxSHOE
Dec 9, 2006 12:38 AM
demitrix
Sep 21, 2004 04:18 PM
jbell
Audio / Security / Video
Jul 6, 2004 11:49 PM
NSXjr
Mar 2, 2004 11:23 AM
jeremy.
Jan 8, 2004 08:35 AM
