Honda S2000 Honda S2000
help with AC condenser replacement?
Old Nov 2, 2006 | 11:08 AM
caseyjholmes's Avatar
Default help with AC condenser replacement?
anyone able to help me? How do I drain the AC condensor lines so I can replace the condensor? A racoon went through the grill of my s2k and took out the condenser and the radiator. radiator was leaking everywhere, but the condensor didn't leak. I got the new radiator and condesor, but I don't know how to empty and refil the AC condesor lines, or what to do it with. Is this what they call an AC recharge? Whats a safe way to empty the condensor lines?
Need help ASAP, was planning to drive it tonight if I can get it up and running in time
Thanks for any help you can provide. I'm pretty technically inclined, and have any tool I need, so feel free to lay it out there for me!
Casey
Old Nov 2, 2006 | 12:15 PM
evil vapor's Avatar
Default Re: help with AC condenser replacement? (caseyjholmes)
Casey, you'll need a machine that will "vacuum" out the gas since it's not advisable to release the gas into the atmosphere. If the system hasn't leaked all the gas out or isn't leaking, I'm sure most shops will be able to vacuum the gas out and recharge it when you make the necessary repairs/replacement.
Old Nov 2, 2006 | 12:28 PM
Default Re: help with AC condenser replacement? (evil vapor)
thats the problem,
the system has refrigerant in it, but the condensor is bent in such a way to where I cannot install the new radiator, and I don't know how to release the refrigerant properly.
I Suppose I have to bring it in to a shop who can do the AC work? Damn, I'll just try and bend it back so I Can fit the new radiator back in, then drive it to the shop..
The system is not leaking, just bent and in the way
Modified by caseyjholmes at 3:21 PM 11/2/2006
OldSchoolFool
Jul 10, 2015 03:22 AM
x_tuh_sy
Dec 11, 2007 05:08 AM
AccordSleeperZzZ
Sep 26, 2006 02:53 PM
suaveshab
Jun 4, 2004 09:39 AM
