Honda S2000 Honda S2000
headrest speaker question
Old Aug 9, 2005 | 03:14 PM
01itr320's Avatar
Default headrest speaker question
Does anyone know if I will need any additional wiring, etc... to hook up headrest speakers that are meant for an 05? Thanks.
Old Aug 9, 2005 | 03:18 PM
Nishant's Avatar
Default Re: headrest speaker question (01itr320)
oem or non oem speakers?
Old Aug 9, 2005 | 03:27 PM
SuzukaBlueAP2's Avatar
Default Re: headrest speaker question (Nishant)
04+ are prewired. If you get the OEM kit it should come with everything that you need.
If you get the S-Pods, like I am going you will need a little wire to go to the harness under the dash from the speakers.
Old Aug 9, 2005 | 04:12 PM
01itr320's Avatar
Default Re: headrest speaker question (ScreaminTeg)
I am looking to buy a set of used oem headrest speakers that are currently on ebay. It only seems to include the speakers.
Old Aug 9, 2005 | 04:15 PM
Nishant's Avatar
wiring is there so thats all you would need
Old Aug 9, 2005 | 04:29 PM
01itr320's Avatar
I had wondered because another ebay listing mentioned that there is a special connecting harness required to hook them up to a 2000 model.
Old Aug 9, 2005 | 04:33 PM
Nishant's Avatar
cause the older models were not prewired, as long as you have an 04+ you will be fine
Old Aug 9, 2005 | 04:43 PM
01itr320's Avatar
Nishant, are you talking about an 04+ car or 04+ set of speakers. Sorry that I am confused.
Old Aug 9, 2005 | 07:18 PM
Nishant's Avatar
04+ year car
Old Aug 10, 2005 | 06:57 PM
01itr320's Avatar
My S is a 2000 model so I guess I'm out of luck. Today I had the parts guys at my work pull the instructions and it says the speakers only work for 04+. I guess my lext option is to look for an aftermarket conversion kit. Thanks for the info.
Old Aug 11, 2005 | 05:39 PM
Nishant's Avatar
s-pods on s2ki.com will be what you want
Old Aug 11, 2005 | 08:20 PM
I'll post pics of 'em as soon as mine arrive if you want.
Old Aug 16, 2005 | 12:03 PM
01itr320's Avatar
Does anyone know if the rear speaker harness from lucid will be the answer to my original question?
Old Aug 16, 2005 | 03:09 PM
.doeboyfresh.'s Avatar
From: Boswanna,street radio,riddin in da regal. PA.LLday
http://www.streetsmarttechnologies.net/
Old Aug 16, 2005 | 07:58 PM
Default Re: headrest speaker question (TeGmAn18)
These are the components I chose for my pods....the pods arrive in two more days!!!
Old Aug 17, 2005 | 04:53 PM
GsrGilbert's Avatar
what size speaker fits in the oem op set?
<------- To lazy to search
Old Aug 17, 2005 | 05:26 PM
Default Re: headrest speaker question (GsrGilbert)
sick speakers ...i love eardrums
Old Aug 17, 2005 | 08:48 PM
Mr. Projekt's Avatar
* B A N N E D *
Phoenix Gold
Old Aug 20, 2005 | 11:53 AM
Default Re: headrest speaker question (MyWayIsSideways)
one more thing...
anyone know where the hell this stupid pigtail is on the 04+ models???? I have dug around and cannot find it!!! ahhhhhhh
Old Aug 20, 2005 | 08:42 PM
Nishant's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScreaminTeg &raquo;</TD></TR><TR><TD CLASS="quote">one more thing...
anyone know where the hell this stupid pigtail is on the 04+ models???? I have dug around and cannot find it!!! ahhhhhhh</TD></TR></TABLE>
will look in my service manual, should show it
Old Aug 21, 2005 | 05:02 PM
beerguy's Avatar
Ditto - I've got an 05 and can't find the pigtail either.
Old Aug 21, 2005 | 05:59 PM
beerguy's Avatar
Actually, I think I answered my own question.
It appears that the plug into the head unit is pre-wired, not the car. You still have to run wires back to the speakers.
Old Aug 21, 2005 | 07:05 PM
Default Re: (beerguy)
I found the pigtail...
it's taped up underneath the dash by blue tape to another wireharness. It's a gray, 4 wire plug. And they don't give you much slack to work with either!
Old Aug 22, 2005 | 05:52 AM
beerguy's Avatar
Default Re: (ScreaminTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScreaminTeg &raquo;</TD></TR><TR><TD CLASS="quote">I found the pigtail...
it's taped up underneath the dash by blue tape to another wireharness. It's a gray, 4 wire plug. And they don't give you much slack to work with either! </TD></TR></TABLE>
Which side?
Old Aug 22, 2005 | 04:34 PM
it's under the driver's side of the dash. If you are able to lay down under there on your back and look up into the dash, you'll see if on your left. It's pretty much straight up from the triangular panel you remove on the side of the center console.
