Honda S2000 Honda S2000
Headlight enquiry....
Old Feb 2, 2007 | 11:32 AM
mark_a_thorpe's Avatar
Default Headlight enquiry....
Hi folks! I REALLY need help with something! I'm not an s2000 owner unfortunately, but am currently undergoing a project wherein I'm planning on mounting a set of s2000 headlights on another car.
anyways, I keep hearing talk of a computer that goes with the headlights? Can this be left out? And simply use the donor car's existing wiring with the s2000 lights?
ANY info would be greatly appreciated! Cheers!
Old Feb 2, 2007 | 11:33 AM
SuzukaBlueAP2's Avatar
Default Re: Headlight enquiry.... (mark_a_thorpe)
I think you might be referring to the HID ballasts. They are necessary in order to make the HID bulbs work.
Old Feb 2, 2007 | 11:37 AM
Default Re: Headlight enquiry.... (SuzukaBlueAP2)
And am i correct in saying that the cluster has a seperate indicator bulb, headlight and finally the HID? Would hte lights function without HID bulbs?
Old Feb 2, 2007 | 11:55 AM
Which cluster? The instrument cluster inside the cabin? I'm not sure since you are in the U.K. and I am in the U.S.
You may have headlamps that have city lights in them just like some JDM cars.
If you don't use the HID bulbs with these headlamps then you won't need the ballasts. However, I would venture to say that light output would be crap unless the proper bulbs were used.
Old Feb 2, 2007 | 11:57 AM
Sorry matey, i meant the headlight cluster. IE, is there a seperate orange indicator bulb, a dipped beam bulb, and the HID? I'm just trying to figure out a way to attach these to another car...
Old Feb 2, 2007 | 01:27 PM
Mr. Projekt's Avatar
* B A N N E D *
You could just use an aftermarket HID kit with D2S bulbs to fit the headlight.
The highbeam is H1, there are (2) T10 sockets for blinkers and (2) normal sockets for single filament illumination.
Old Feb 2, 2007 | 01:32 PM
liam821's Avatar
25 Year Member
Default Re: Headlight enquiry.... (Mr. Projekt)
A stock s2000 ballast looks like this..
2008fijibluesi
Lighting
12
Jan 3, 2008 04:40 PM
MikeTV
Jan 28, 2005 09:00 AM
Kelvin96GSR
May 19, 2004 01:34 AM
NightHawkC5
Honda S2000
Jan 25, 2004 11:15 AM
B18EG6
Honda S2000
Oct 17, 2002 05:56 AM
