Honda S2000 Honda S2000
Headlamp adjustability
Old Oct 27, 2005 | 10:38 AM
revvin9k's Avatar
Default Headlamp adjustability
I was recently involved in a little fender bender and opted to replace my headlamps with the JDM pieces. I was "told" that there maybe some issues of my light blinding oncoming drivers since they obviously drive on the opposite side. I was also "told" that there is no adjustment that can be made to compensate for the difference. Is some one pulling my leg? I thought ALL headlights were able to be adjusted. Someone please shed some light on this.
Cliff notes: Can adjustments be made to the JDM headlamps?
Old Oct 27, 2005 | 11:33 AM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: Headlamp adjustability (S2K NUB)
There is an adjustment **** on all OEM S2000 headlights that I've seen. Its a round gray **** with teeth and a bolt in the middle, located behind where the high beam would be.
If you really worried, have Honda adjust your headlights. One of your headlights is supposed to shine higher than other, I think the JDM version just reverses it.
Old Oct 27, 2005 | 11:34 AM
revvin9k's Avatar
Well, I just got them in no more than a ten minutes ago and my it's true. There is NO ADJUSTABILITY for the actual head lamp(HID) only the inner driving light. Makes no sense to me why they would'nt allow adjustments on this. Here is a pic....am I not seeing something correctly? Is there an adjustment?
Old Oct 27, 2005 | 11:37 AM
WowOzYouRock's Avatar
ill trade you
Old Oct 27, 2005 | 11:39 AM
revvin9k's Avatar
Default Re: Headlamp adjustability (Y2K_S2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Y2K_S2K &raquo;</TD></TR><TR><TD CLASS="quote">ill trade you </TD></TR></TABLE>
Such a nice guy....always willing to help some one out......... .
J/K.....WTF DO I DO?
Old Oct 27, 2005 | 11:40 AM
* B A N N E D *
Correct me, but I see two adjustment *****. Let me look at my Service Manual, and I'll get back to you. I adjusted the AP2 headlights on my AP1 with one of those.
Old Oct 27, 2005 | 11:45 AM
revvin9k's Avatar
Default Re: Headlamp adjustability (Slideways2000)
Note: Those are ONLY for the inner lamp, to adjust up or down is one ****, and the other is to move it right to left....correct me if i'm wrong.
Old Oct 27, 2005 | 11:56 AM
* B A N N E D *
Yes those adjustment ***** move the HID diffusers inside of the projector to adjust your headlight cut off, according to the manual. As far as adjusting the WHOLE headlight, it doesn't show anything.
Old Oct 27, 2005 | 11:59 AM
revvin9k's Avatar
Honestly, Sidewayss2000, you took a big load off my shoulders. Thank you so much for some useful info.
EDIT: So will I be able to adjust the beam from not being in other drivers eyes...up and down? Just checking.
Modified by S2K NUB at 3:10 PM 10/27/2005
Old Oct 27, 2005 | 12:00 PM
now kiss him ... and i dont wanna see that
Old Oct 27, 2005 | 12:14 PM
Nishant's Avatar
neither do I
Old Oct 27, 2005 | 12:43 PM
* B A N N E D *
Yes you can adjust the beams. The top **** moves up and down, the lower one goes left and right. Here's the headlight adjustment procedure according to the manual:
Prep: Park on level surface, check tire pressures, driver or someone who weighs the same should sit in the driver's seat.
1) Park car 25 ft from wall.
2) Turn on low beams.
3) Measure height of headlight, from the ground to the aiming dot in the middle of the housing, infront of the HID.
4) Measure the cut-off height of the light beam at the wall. It should be 2" lower than the height of the headlight itself.
Good luck.
ImPuLsIvE
May 21, 2008 12:33 PM
honda94accord
Apr 25, 2007 05:43 PM
sir91
Jun 12, 2005 08:32 PM
2Ting
Honda S2000
Jul 14, 2002 07:06 PM
