Honda S2000 Honda S2000
Hard top question
Old Mar 13, 2004 | 05:51 PM
dinosa21's Avatar
Default Hard top question
Is there a new hard top that turns the trunk in to a hatch. Ive only seen one pic awile back. I cant seem to find it again.
Old Mar 13, 2004 | 06:11 PM
rockwilda's Avatar
Default Re: Hard top question (dinosa21)
it doesn't turn the trunk into a hatch literally. it's just built to connect back there, theres a pic of the trunk and the "hatch" of the HT open flying around somewhere.
Old Mar 14, 2004 | 03:24 PM
[S2X]'s Avatar
it called Mooncraft. i got some pics but i could not find a place to host it. looks gooooddd!!!
Old Mar 14, 2004 | 04:15 PM
dinosa21's Avatar
Default Re: ([S2X])
Yah it does Its to bad that it is only an add on. kind of worthless to have then. If they made it to bolt up in the place of the trunk that would be even better.
Old Mar 14, 2004 | 04:46 PM
New Image's Avatar
Default Re: (dinosa21)
peronally i disagree with that, it looks good as an add-on. You probably have seen some pictures of it if you read Honda Tuning. It was in the February 04 issue. This hard top adds a rear quarter window and a trunk lip spoiler in its design. It is currently used on Spoon Sports' new endurance machine. Spoons S2K will compete in Japan's Super Taikyu series. This hardtop is wind tunnel-tested to improve fuel consumption by 8% and increase top speed by 6.2 mph. It is designed by Mooncraft and Spoon will sell it in April 04. It is unknown at this time whether it will be available in the U.S.
Old Mar 14, 2004 | 05:38 PM
dinosa21's Avatar
Default Re: (94JDMEG)
nice info i will have to read up on it more, but the added weight of back window Thats why i thougt it would be a good idea to get rid of the trunk.
Old Mar 14, 2004 | 06:03 PM
New Image's Avatar
No, I understand...you have a good point too...only if we could see it in-person for ourselves could we have a good idea of its design logic.
Old Mar 14, 2004 | 07:39 PM
M-Type's Avatar
hope the owner of these pics dont mind me posting.
Old Mar 14, 2004 | 08:31 PM
Mr.Fairlady's Avatar
Default Re: (M-Type)
I've seen that.....that was how the supposed "*NEW* S2200"(photoshopped?) was gonna look like stock.
Kinda makes it look like an old 280Z....I dig it.
although...I'm sure you could probably get the mugen Carbon top for the price of that one?????I'd stick w/ the regular hardtop.
Old Mar 15, 2004 | 11:10 AM
evil vapor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94JDMEG &raquo;</TD></TR><TR><TD CLASS="quote">No, I understand...you have a good point too...only if we could see it in-person for ourselves could we have a good idea of its design logic.</TD></TR></TABLE>
design logic is a smoother airflow across the roof of the car and making the air more effective for the rear spoiler, reducing the need for one that sits higher and is wider. IMO, it looks ugly, but I also like ugliness like the stack cluster and spoom wheels.
Old Mar 15, 2004 | 01:49 PM
New Image's Avatar
Default Re: (vapor)
I understand physics. I was refering to how it is made seperate from the trunk. In-person I would be able to understand that part of the design logic. When they built this hardtop drag wasn't all they considered. They needed to work with what Honda created and keep the trunk functional.
Old Mar 15, 2004 | 03:00 PM
M-Type's Avatar
if you look closely there are cut outs on the hatch and it seems like you can still open the trunk.
Old Mar 15, 2004 | 04:00 PM
evil vapor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94JDMEG &raquo;</TD></TR><TR><TD CLASS="quote">I understand physics. I was refering to how it is made seperate from the trunk. In-person I would be able to understand that part of the design logic. When they built this hardtop drag wasn't all they considered. They needed to work with what Honda created and keep the trunk functional. </TD></TR></TABLE>
the rear section is a hinge type that raises, then one can open the trunk
Old Mar 15, 2004 | 09:20 PM
New Image's Avatar
Default Re: (vapor)
yeah
Old Mar 16, 2004 | 03:33 AM
JL9000's Avatar
With the mooncraft top on the trunk is still functional.
I don't like the look, but it definately makes sense in fluid dynamics.
Old Mar 16, 2004 | 03:52 AM
00 FBP ItR's Avatar
Default Re: (JL9000)
Functional?
Not fond of the looks...
But.. Function before Fashion.
Old Mar 16, 2004 | 06:25 AM
Mr. Bagel's Avatar
could be rules in a particular class, but my thought would be for suspension adjustments - that can be done quickly in the pits by lifting up the rear hatch, and any fuel cell/fuel line maintenance that needs to be done from the rear.
Old Mar 20, 2004 | 07:42 PM
TEAM-Datum1's Avatar
Default Re: (Mr. Bagel)
Right on bro.
Old Mar 24, 2004 | 04:36 PM
VTEC 101
Guest
Posts: n/a
Nice looking S2000
Old Mar 26, 2004 | 06:55 PM
spirit R
Guest
Posts: n/a
Default Re: (VTEC 101)
If you look closely you will notice that no angle is more than 15 degrees the point at which air flow begins to seperate from the surface it's traveling over cuasing turbulence.
Having seen the moon craft hatch up close it's really only for racing. And only for cause with gravity feed fuel cells. Suspension tuning most likely will require the removal of the top.
The need for this arose when at the current power level there top speed was drag limited. Other cars in that class run up to and over 170. Part of this is possible due to the extremely low altitude of there race tracks and the sub zero temps some races are run in.
Spoon has other changes to there package and J's has stepped up there aero programs as well.
With a solid paint scheme like red and some gold BBS rims with a polished lip it looks like the old ferrari GT cars with a modern touch
Certainly nowhere near as fugly as the hatch back Z3 BMW was
Old Mar 27, 2004 | 02:16 PM
Razor's Avatar
Default Re: (Duke Togo)
i think it looks fugly. oem or mugen ht are better choices.
just my .02 cents.
Old Mar 27, 2004 | 08:27 PM
spirit R
Guest
Posts: n/a
Default Re: (Razor)
This top was built to win races
that's really it's first and only point.
either you find beauty in it's pureness or you don't.
crx_si-r
Nov 12, 2008 09:54 AM
REDTOPAlchemy
Aug 25, 2004 01:29 PM
rough_draft
Jul 10, 2004 03:20 PM
F120man
Dec 19, 2002 05:20 AM
16vracer
145
Apr 10, 2002 01:58 PM
