Honda S2000 Honda S2000
GTECH???
Old May 16, 2006 | 04:08 PM
Hondageek's Avatar
Default GTECH???
has anyone used the GTECH SS? i have one i used in my civic and it worked fine, i tried moving it to my S and the shift lights will not work. around 7500 to 8000 one of them will flash then it acts like im not reving any more when im still on the gas. is it a problem with my gtech or could it be vtec messing it up?
Old May 16, 2006 | 06:20 PM
Francesco's Avatar
Default Re: GTECH??? (Hondageek)
never used it, but i always hear about how unaccurate those things are.
Old May 16, 2006 | 06:45 PM
Hondageek's Avatar
Default Re: GTECH??? (Francesco)
hp and tq was usually what it was said to be according to honda and the shiftlights always worked right which was the main reason i bought it. i dont care about anything but the shift lights in the S.
Old May 16, 2006 | 10:10 PM
iam7head's Avatar
Default Re: GTECH??? (FR-MOB: Francesco)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FR-MOB: Francesco &raquo;</TD></TR><TR><TD CLASS="quote">never used it, but i always hear about how unaccurate those things are.</TD></TR></TABLE>
really? all the guys i know with the meter seem to like it, it's not dead on but it's pretty accurate from what i heard.
Old May 16, 2006 | 10:28 PM
SilverDc2's Avatar
Default Re: GTECH??? (iam7head)
i have one, its pretty accurate i would say.
just have to know how to use it.
Old May 16, 2006 | 11:12 PM
Project22a's Avatar
Default Re: GTECH??? (SilverDc2-Ap1)
RPM/Shiftlight and timing features work great for me. Don't bother with the dyno function though.
Old May 17, 2006 | 06:18 AM
Luder94's Avatar
Default Re: GTECH??? (Project22a)
I use the autometter DPIC. It's really accurate and has a lot of driving dynamic metrics. Try one!!!
Old May 17, 2006 | 06:58 AM
JDM knowledge's Avatar
Default Re: GTECH??? (Luder94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luder94 &raquo;</TD></TR><TR><TD CLASS="quote">I use the autometter DPIC. It's really accurate and has a lot of driving dynamic metrics. Try one!!!</TD></TR></TABLE>
didnt even know they had that.
Old May 17, 2006 | 09:17 AM
Hondageek's Avatar
Default Re: GTECH??? (JDM knowledge)
project22a and silverdc did you both use them in the s2000 or something with lower redline? i tried moving the calibration to 8000 last night instead of 6500. it wont really let me calibrate, it keeps going to the "how many cylinders" and "after market ignition" part then i have to try to find out where my rpm's are out on the -/32 thing.
Old May 17, 2006 | 09:21 AM
Mr. Projekt's Avatar
* B A N N E D *
I'm thinking it says "aftermarket ignition" because we have coil-on-plugs vs. the normal distributor ignition.
Old May 17, 2006 | 09:36 AM
Hondageek's Avatar
Default Re: GTECH??? (FR-MOB: Projekt)
its an option, it doesnt tell you if you have one or not. i had the k20 in the civ so it was coil packs. it says ex: jocobs and i think msd is on the list too. i called gtech just a moment ago and he says that getting a light plug from any auto parts store and tappin into the altenator power wire will help pick up signal and also to try some calibrating in different ways; such as changing where i calibrate to and turning on the defroster and headlights causing the altenator to work a little more and increase the signal.
Old May 17, 2006 | 10:03 AM
Project22a's Avatar
Unfortunately, I've only used it on my Prelude. I'll put in my s2k tonight and see if I have any problems.
Old May 18, 2006 | 07:59 PM
Hondageek's Avatar
any luck project22? you never posted back.
Old May 19, 2006 | 04:08 PM
Project22a's Avatar
Works fine for me. I have a different GTECH Though. I have the older GTECH Pro Comp. (Black housing with blue screen) and upgraded to RR firmware.
Youngcity
Honda Civic (2001 - 2005)
12
Jul 30, 2007 02:09 PM
m1northreat
Honda S2000
23
Jul 23, 2007 08:39 AM
Spec R
Feb 17, 2006 10:48 AM
99fbpem1
Jun 24, 2003 08:09 AM
