Honda S2000 Honda S2000
grinding from 1st to 2nd??
Old Nov 28, 2004 | 06:47 PM
s2kDinesh's Avatar
Default grinding from 1st to 2nd??
i just got my 05 s2k...and when it is cold outside..like in the morning or night and i havent drivin her for awhile....the gears grind when switching from 1st to 2nd....and only in those gears..it stops after about 15 minutes...any ideas on wut it is?
Old Nov 28, 2004 | 08:15 PM
oakfloor's Avatar
Default Re: grinding from 1st to 2nd?? (s2kDinesh)
the honda supplied tranny oil will thickin up when cold. you must drive it for a while until it warms up so be easy on it. synthetic oil may help.my 00' has redline mt-90. and was a improvement when cold. but the '05s have carbon fiber synchros, and may not like syn oil.
Old Nov 28, 2004 | 08:39 PM
papa5murf's Avatar
Default Re: grinding from 1st to 2nd?? (oakfloor)
it's normal. let the car warm up... ... make sure you have 3 bars before you start to aggresively drive the car... no vtec till 3 bars..
Old Nov 29, 2004 | 10:46 AM
Nishant's Avatar
Default Re: grinding from 1st to 2nd?? (03s2kblue)
its somewhat normal in our cars. i haven't ran into that so maybe i am lucky? just don't drive hard when its cold. another option is to let the car warm up before you take off
Modified by Nishant at 12:48 AM 12/9/2004
Old Nov 29, 2004 | 03:24 PM
Atheist's Avatar
Default Re: grinding from 1st to 2nd?? (Nishant)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nishant &raquo;</TD></TR><TR><TD CLASS="quote">its somewhat normal in our cars. i haven't ran into that so maybe i am lucky? just DONT drive hard when its cold. another option is to let the car warm up before you take off</TD></TR></TABLE>
fixed
Old Dec 1, 2004 | 06:47 AM
CWESTINAP1's Avatar
if you shift with too much force, and not enough finesse, it WILL grind.
Old Dec 1, 2004 | 08:33 AM
Razor's Avatar
Default Re: grinding from 1st to 2nd?? (CWESTINDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CWESTINDC2 &raquo;</TD></TR><TR><TD CLASS="quote">if you shift with too much force, and not enough finesse, it WILL grind.</TD></TR></TABLE>
exactly. thats why i shift slow and cautiously when the tranny is cold. people think i'm crazy but they have no idea how fragile the s2k tranny is.
Old Dec 1, 2004 | 11:41 AM
kdrlinus's Avatar
Default Re: grinding from 1st to 2nd?? (Razor)
I seem to have similar problems but not just when its cold. at first i thought it was just me needing to get used to my car but i have had it now for a year and it still grinds. it doesnt matter what temp the engine is at and it doesnt seem to matter if im driving hard or not. actually it seems to happen more when im feathering it. sometimes i need to push the clutch to the floor to get it in .. and it still grinds
Old Dec 1, 2004 | 01:18 PM
B2FiNiTY's Avatar
Default Re: grinding from 1st to 2nd?? (kdrlinus)
Sounds like it could be the clutch, gears or syncros.
Old Dec 1, 2004 | 04:23 PM
oakfloor's Avatar
1-2 gear clash is a common s2k issue. double clutching may help. have you changed you tranny oil, or clutch fliud?
Old Dec 1, 2004 | 06:25 PM
s2kDinesh's Avatar
nop not yet lol....i havnt even had the car for a week...
Old Dec 1, 2004 | 09:04 PM
oakfloor's Avatar
O.K. I went back and re-read your first post. take it back to the dealer. a new '05 should not have a 1-2 clash like the old ones do. they changed the trannys in'04. now if it gets better when it gets warmed up then it it may be normal. I use redline mt-90 in mine 00' with 22k and it helped. go to s2ki.com and try a search. Good luck with it
Old Dec 1, 2004 | 09:19 PM
SimbaDogg's Avatar
i'm having a problem w/ my 02. not when its cold, cuz i dont even drive it until it warms up to @ least 2 bars...but when i'm @ high rpm in 1st, and make the shift to 2nd, it grinds sometimes. i heard this happended quite a bit w/ 02-03 trannys, but there was never a TSB for it. Any body got some advice for me, i switched to gm syncromesh too...and still no fix
Old Dec 7, 2004 | 08:54 PM
bs2k's Avatar
Default Re: grinding from 1st to 2nd?? (SimbaDogg)
some guy told me u should even shift it fast from first to second on s2k, i posted something like this also just a few hours ago. It happens to me every morning. I drive for like 2 miles, Get on the freeway, drive like 2 miles, and when im off the free way it stops. So its just the car getting warmed up, or when u got the car, u were pushing the car from first to second and it saw some problems. Ive shifted fast from 1 to 2 and now i stop cuz ive grinned a few times.
Old Dec 7, 2004 | 08:56 PM
bs2k's Avatar
Default Re: grinding from 1st to 2nd?? (bs2k)
Some guy told me you SHOULDNT****** my bad lol
Old Dec 8, 2004 | 12:21 PM
mimimomomiki2's Avatar
oh....
maybe that was the sound i heard on my 03...
this kinda.. bangin sound from transmission or whatever right?
hmm cuz i took it to the dealer... they said nothin wrong
so maybe..-_- its cuz the car's not warmed up..and
canada is freakin cold right now...
Old Dec 8, 2004 | 08:20 PM
Razor's Avatar
Default Re: grinding from 1st to 2nd?? (mimimomomiki2)
are you sure you mean "notchy" instead of grind? some people confuse these words.
the s2000 transmission is naturally notchy, especially when cold.
Old Dec 9, 2004 | 07:15 AM
fknfast's Avatar
GainMpg1
Oct 26, 2008 04:51 PM
Minirex61
Honda Civic (2001 - 2005)
Feb 16, 2007 12:09 PM
Project SSAP1
Honda S2000
Jan 12, 2004 07:54 PM
io_burn
Jun 17, 2003 04:14 PM
int3gra
Oct 9, 2001 05:51 PM
