Honda S2000 Honda S2000
Gear backlash during engine braking?? Thoughts?
Old Feb 20, 2007 | 04:34 PM
Smitty2k's Avatar
Default Gear backlash during engine braking?? Thoughts?
Hey everybody,
First post and brand new to forums in general...recently purchased an '01 Silverstone/Red int. S2000 with 62,xxx...my dream car. Have put about 500 miles on it so far, but am getting a buzzing from the transmission in 2nd-5th during engine braking, especially b/t 3-4k rpm. It sounds a lot like heat shield rattle so I took it to my local Honda dealer. First they said it was "resonance" but I didn't buy it. A more thorough inspection and research and they came up with "Gear backlash" and declared that the problem was common on S2K's like mine and the fix was relatively simple: replace the clutch...any thoughts? I'd appreciate the help.
Old Feb 20, 2007 | 04:48 PM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: Gear backlash during engine braking?? Thoughts? (Smitty2k)
Technical Service Bulletin: Buzzing clutch upon deceleration. Caused by worn clutch disk springs.
Fix: Replace with 02+ friction disk, resurface flywheel as necesary.
Gear backlash is not a clutch problem. Fire your mechanic.
Old Feb 20, 2007 | 04:52 PM
Smitty2k's Avatar
Default Re: Gear backlash during engine braking?? Thoughts? (Mr. Projekt)
Thanks for the quick response. It seems they recommended an entirely new clutch disk, pressure plate, and throwout bearing...overkill? At $1,367.xx it's not a cheap fix I suppose...thankfully the dealer took off some because of the buzz. Also, would it be better to replace the stock components with aftermarket street clutch/flywheel now or replace with OEM?
Old Feb 20, 2007 | 04:58 PM
* B A N N E D *
They're ripping you off.
$550 for all the parts including a new flywheel, so 1360 - 550 = $800 in labor?
http://www.hondaautomotivepart...LUTCH
Old Feb 20, 2007 | 05:00 PM
Smitty2k's Avatar
Thought it seemed steep..thanks for the help!
Old Feb 20, 2007 | 07:52 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
They're not ripping you off. Dealers charge between $45-$90 per hour of labor. If the books say that this is a 10hr job...then thats what they charge you. Plus you might be getting parts at a wholesale price sometimes even if it is from a dealer. The dealer the OP went to might not have been selling wholesale parts. Im not saying its a reasonable price or that you should pay it..im just saying that they're not "ripping you off". Thats just what they charge. ripping you off would be charging $400 for the whole thing, quoting you more, and pocketing the rest as a 3rd party or something else deceptive. They're not decieving you...they just charge more.
Bottom line: GO SOMEWHERE ELSE! lol. buy the parts wholesale and get them installed at somewhere else. Make sure its reputable. One of the advantages of going with dealers is that you get a pretty bulletproof warranty, and they use "genuine honda" stuff to put your car back together. Like honda bond. Expensive *** gasket maker....but it RULES.
Old Feb 20, 2007 | 08:06 PM
evil vapor's Avatar
Default Re: Gear backlash during engine braking?? Thoughts? (B serious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B serious &raquo;</TD></TR><TR><TD CLASS="quote"> Like honda bond. Expensive *** gasket maker....but it RULES. </TD></TR></TABLE>
Ever try the toyota stuff? I swear it works better than honda bond.
Old Feb 20, 2007 | 09:10 PM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smitty2k &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the quick response. It seems they recommended an entirely new clutch disk, pressure plate, and throwout bearing...overkill? At $1,367.xx it's not a cheap fix I suppose...thankfully the dealer took off some because of the buzz. Also, would it be better to replace the stock components with aftermarket street clutch/flywheel now or replace with OEM? </TD></TR></TABLE>
don't bother with oem stuff(exedy), people with 2nd and 3rd replacement still has the buzz once the mileage piled up.
replacing clutch on the S took a long **** time, not like a b series motor that you can hump it off and on in 2 hours flat.
&lt;--doing a clutch job on ae86 soon
Old Feb 20, 2007 | 09:31 PM
5 Skware's Avatar
I missed the boat
Default Re: Gear backlash during engine braking?? Thoughts? (evil vapor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evil vapor &raquo;</TD></TR><TR><TD CLASS="quote">Ever try the toyota stuff? I swear it works better than honda bond. </TD></TR></TABLE>
Blasphemy
bimmeracer
Mar 27, 2009 10:59 PM
rollagti
Sep 28, 2008 09:47 PM
george34
107
Sep 2, 2007 02:42 PM
Jmm0056
Sep 12, 2001 01:54 PM
