Honda S2000 Honda S2000
EPS light.
Old Jul 16, 2006 | 01:33 PM
fknfast's Avatar
Default EPS light.
My focking EPS light is on and i hear its a pain to fix..AGHHHHHH im so pissed.. anyone end up gettin rid of this light/problem in an easy way?
Old Jul 16, 2006 | 02:55 PM
SuzukaBlueAP2's Avatar
Default Re: EPS light. (fknfast)
My guess would be if that light is on then there is something wrong with your power steering system and you should find out what it is.
I don't know if a dealership has to do that or what.
Old Jul 16, 2006 | 03:06 PM
CoolKat's Avatar
Like suzukablue said, there's a good chance that maybe a wire or an electrical component failed on ya.
I'm not really sure how to go about this but if you haven't checked s2ki.com then I suggest you check out the forums there, they have a lot of useful info.
Old Jul 16, 2006 | 07:06 PM
kane.s2k's Avatar
is your VSS not hooked up for any reason?
Old Jul 16, 2006 | 09:58 PM
fknfast's Avatar
Default Re: (kane.s2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kane.s2k &raquo;</TD></TR><TR><TD CLASS="quote">is your VSS not hooked up for any reason?</TD></TR></TABLE>
i havent touched a thing its bone stock i pulled it out of the garage to wash it and when i go to pull it back in i saw the light and no PS... right away i knew something was up i just never encountered this problem before.
Old Jul 16, 2006 | 10:22 PM
kane.s2k's Avatar
have you driven it since the EPS came on?
Old Jul 17, 2006 | 12:10 AM
Mr. Projekt's Avatar
* B A N N E D *
EPS fuse? Is that the box under the driver side fender?
See if the control unit is shorted. The box by the battery.
Old Jul 17, 2006 | 05:24 AM
Francesco's Avatar
Default Re: EPS light. (FR-MOB: Projekt)
As long as the car has driven fine I would reset the ECU and see if it comes back on.
Old Jul 17, 2006 | 07:38 AM
kane.s2k's Avatar
sigh...the eps controller isn't apart of the ECU. Sometimes the EPS will disable itself if you don't drive around and give steering input. It will come back on if this is the case from just driving it for 5 minutes.
Old Jul 17, 2006 | 03:34 PM
MasterKwan's Avatar
You can overheat the EPS to by sitting still and turning the wheel back and forth. Eventually assist will go away if it gets hot enough.
Old Jul 17, 2006 | 03:57 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kane.s2k &raquo;</TD></TR><TR><TD CLASS="quote">Sometimes the EPS will disable itself if you don't drive around and give steering input.</TD></TR></TABLE>
Such as?
My S2k sits all winter and I don't get an EPS light. Maybe I've been lucky the past 2 years?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MasterKwan &raquo;</TD></TR><TR><TD CLASS="quote">You can overheat the EPS to by sitting still and turning the wheel back and forth. </TD></TR></TABLE>
I'm actually just curious where you got this info...
Old Jul 17, 2006 | 04:18 PM
kane.s2k's Avatar
I meant the car idling and not moving. Not sitting there unused.
Old Jul 17, 2006 | 04:20 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kane.s2k &raquo;</TD></TR><TR><TD CLASS="quote">I meant the car idling and not moving. Not sitting there unused.</TD></TR></TABLE>
Gotcha.
I don't know why anyone would do that...lol
Old Jul 28, 2006 | 08:23 PM
fknfast's Avatar
Default Re: (SuzukaBlueAP2)
Fn light is still on and i cant figure this out..AGHHHHHHHHH
Old Jul 28, 2006 | 08:29 PM
Agent Zero's Avatar
Default Re: (fknfast)
Sorry guys... But what and the hell is an EPS light??? Sorry for the dumb **** but this is killing me.
Old Jul 28, 2006 | 09:10 PM
Default Re: (redsihatchback)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redsihatchback &raquo;</TD></TR><TR><TD CLASS="quote">Sorry guys... But what and the hell is an EPS light??? Sorry for the dumb **** but this is killing me. </TD></TR></TABLE>
Electronic Power Steering
jdmrida
Nov 21, 2008 08:58 AM
C-West Civic
Dec 18, 2007 04:34 PM
ROB8387
Dec 16, 2006 02:00 PM
TX'SleepyDC5
Apr 18, 2004 10:20 PM
tweak
Jan 13, 2004 08:21 AM
