Honda S2000 Honda S2000
engine rattling when cold
Old Dec 4, 2008 | 10:35 AM
nfrs2k87's Avatar
Default engine rattling when cold
my engine starts rattling when cold after RPM drops to 1.5K. it goes away when its hot. but it happens every cold start up. Is it time for a new time chain or valve adjustment?
Old Dec 4, 2008 | 12:49 PM
gearhead313's Avatar
25 Year Member
chain tensioner
Old Dec 9, 2008 | 12:46 AM
my_honda_s2k's Avatar
chain tensionar? i also have that problem. is it common?
Old Dec 10, 2008 | 07:09 AM
White Smoke's Avatar
i my honda
Global Mod
The TCT tick is very very fast. How fast is this noise you are talking about?
Old Dec 13, 2008 | 08:55 AM
nfrs2k87's Avatar
its not a really fast tick. its like a marble rattling in the engine every half second or so.
Old Dec 13, 2008 | 09:06 AM
Black S2K's Avatar
most likely ur tct
Old Dec 13, 2008 | 11:13 AM
s2kdre's Avatar
tct makes noise all the time when its bad! My ap2 always had a loud valvetrain for a few min on cold starts.
Old Dec 13, 2008 | 12:59 PM
S2KFTW's Avatar
if anything have your buddy start it when it's cold you you can listen under the hood. hopefully then you can localize the sound a part of the car. I would check the exhaust stuff since something could be a little loose but when the car warms up that tightens everything and that could be why the noise goes away.
Old Dec 15, 2008 | 11:34 AM
bigmacnfries's Avatar
^^^ i think i have that issue - engine fast ticks for quite a while, then everytime it annoys me enough to have a look, it's gone! It was more noticeable when i added a more open header and test pipe
Old Dec 17, 2008 | 01:16 PM
RedLineFuryMG's Avatar
A classmate had this problem on his car when we were going to Wyotech. It wasn't an s2k but it was a Honda Engine. Every time he started his car you could hear a rattle noise and then it would go away after a few seconds. A few weeks later he blew up his engine. When he tore it apart he said it was his cam bearings that caused it(don't remember if it was cam or other bearings)... Not sure if this is your case.
wv_treehanger
Nov 5, 2009 08:06 AM
kar_the_terrible
Sep 5, 2004 06:56 PM
jdmstreethatch
Jan 20, 2004 11:51 PM
