Honda S2000 Honda S2000
Engine Noise questions.
Old Jun 22, 2010 | 01:47 PM
bigizsosexy's Avatar
Default Engine Noise questions.
Hello all,
I have had my s2000 Ap2 for about 6 months now, i noticed quite a bit of engine noise but was told its only normal. Is there any type of additive or type of oil I can run to quite the motor down a bit....? The noise almost sounds like the valves need adjusting, but I am only at 31k.....Shoot me some support.
Old Jun 22, 2010 | 01:51 PM
The Prophet.'s Avatar
Default Re: Engine Noise questions.
what does it sound like? and are you judging this from the engine bay or from the drivers seat while driving? give some details!
and yeah, valves can get out of wack so if you havent had an adjustment already, you should. there was a timespan when my motor was having problems and adjusted my valves about 5 times in 6 months. haha
Old Jun 24, 2010 | 12:13 PM
Well the noise is heard from the drivers seat. Sounds like a tick that gets louder as the motor revs increase, nothing serious that effects performance or driving. Just an annoyance. any ideas? I am going for a 30k check up soon that's required by manual but should I have them check the valveS?
Old Jun 24, 2010 | 12:58 PM
bigmacnfries's Avatar
could be the Timing Chain Tensioner
Old Jun 24, 2010 | 01:21 PM
JUSTINTHECOASTI's Avatar
^agreed, sounds like the timing chain tensioner, and if you dont know when you got your valves adjusted then do that also, best of luck to you
Old Jun 26, 2010 | 01:48 PM
Sounds good, will let you guys know the outcome!
Old Jun 26, 2010 | 02:47 PM
also it could be your knock sensor but those throw a cel code P0324 I think..let us know I had a similar problem back in 07
Old Jun 26, 2010 | 09:29 PM
IntegType7's Avatar
Old Jun 27, 2010 | 09:18 AM
DumpedSi's Avatar
I agree with timing chain tensioner. Theres a "how to" fix on S2ki that will fix the issue. If you replace the TCT, its likely to go out just as quick.
Old Jun 30, 2010 | 02:17 PM
Can you please post the link. Thanks
Old Jun 30, 2010 | 02:25 PM
here is a link to a video that you guys say is the Timing Chain Tensioner.
http://www.youtube.com/watch?v=F7YWObOi5zQ
This is much much much louder than mine, if this was rated as a 10 for being the loudest mine would prob be a 3 or 4.........
Old Jun 30, 2010 | 03:06 PM
get your valves adjusted then let us know
crunchman
Honda CR-V & Element
17
Jan 10, 2012 05:15 AM
Elbowpunk
Mar 23, 2006 11:01 PM
MODsjtown
Jan 4, 2005 01:05 PM
coolgsr
Dec 16, 2003 07:30 AM
yellowbuffalo
Apr 11, 2002 09:08 PM
