Honda S2000 Honda S2000
Engine damper
Old Apr 20, 2005 | 03:41 PM
SuzukaBlueAP2's Avatar
Default Engine damper
Has anyone ever done tests with the J's engine damper to see it's positive, or negative effects, on WHP and torque trasnferred to the ground with and without it?
Old Apr 20, 2005 | 06:11 PM
RZFD's Avatar
Default Re: Engine damper (ScreaminTeg)
Um... Why would they?
Old Apr 20, 2005 | 06:27 PM
Default Re: Engine damper (R0ck*)
For the same reason some poly mount inserts do...they lessen the amount the engine moves allowing more power to be transferred through the drivetrain and not lost.
Old Apr 20, 2005 | 06:46 PM
Francesco's Avatar
i hear it gets in the way with some other aftermarket parts...
Old Apr 24, 2005 | 12:16 PM
evil vapor's Avatar
Default Re: Engine damper (Francesco)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Francesco &raquo;</TD></TR><TR><TD CLASS="quote">i hear it gets in the way with some other aftermarket parts...</TD></TR></TABLE> the only thing that would get in the way is a SC or turbo. Measuring hp lost or gained by this mod is very difficult. The effects of shifting and engine vibration/torque dampening is enough for most people.
Old Apr 25, 2005 | 06:39 AM
Mr. Bagel's Avatar
seems difficult to measure indeed. but only drag racing the car on a strip would indicate any improvements within the 60ft. times. not much else.
Old Apr 25, 2005 | 11:05 AM
PNB's Avatar
PNB
GatorNATION
Default Re: Engine damper (Mr. Bagel)
I am sure that there is SOME positive effect, but nothing that can really be measured per say.
Old Apr 25, 2005 | 12:38 PM
glagola1's Avatar
Default Re: Engine damper (PNB)
Yeah, the positive affect is shaking your car and subsequently, your *** to death at idle. Fun stuff.
Old Apr 25, 2005 | 02:15 PM
honda9krpm's Avatar
it helped me with 2nd to 3rd gear shift
engine vibrates a lot less with a vortech supercharger and the dampender
unfortunately my current turbo is in the way. I gotta find anotherway of mounting this dampener.
Old Apr 26, 2005 | 06:43 AM
glagola1's Avatar
Default Re: (honda9krpm)
Just curious how it helped a 2nd to 3rd shift?
Old May 5, 2006 | 09:29 AM
djnikko's Avatar
Default Re: (glagola1)
Does anyone have a pic of this installed? I would like to see how it mounts to the engine.
Thanks
Old May 5, 2006 | 09:49 AM
Luder94's Avatar
Default Re: (djnikko)
I definitely notice a quiet rattle with the J's Racing ETD as oppose to the clickity-clank I was getting in my engine bay without it.
The shifter rattle is non-existent now wth the ETD. I don't notice any improvements in shifter feel or smoothed out shift gates. My shifter still feels minty fresh as it did back when the car had 10 miles on it....then again, I don't think I've ever let my trans fluid get used over 10k miles.
Old May 5, 2006 | 10:08 AM
evil vapor's Avatar
Default Re: (Luder94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luder94 &raquo;</TD></TR><TR><TD CLASS="quote">I definitely notice a quiet rattle with the J's Racing ETD as oppose to the clickity-clank I was getting in my engine bay without it.
The shifter rattle is non-existent now wth the ETD. I don't notice any improvements in shifter feel or smoothed out shift gates. My shifter still feels minty fresh as it did back when the car had 10 miles on it....then again, I don't think I've ever let my trans fluid get used over 10k miles.</TD></TR></TABLE>
And most likely you rarely speed/power shift or grind gears.
Old May 5, 2006 | 10:31 AM
Luder94's Avatar
Default Re: (vapor)
I do power shift from time to time (but only at "events").
I've been known to grind in the 2-3 upshift when my hand gets super excited and is slightly faster than my left knee/ankle/foot.
Old May 5, 2006 | 10:43 AM
Francesco's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luder94 &raquo;</TD></TR><TR><TD CLASS="quote">I do power shift from time to time (but only at "events").
I've been known to grind in the 2-3 upshift when my hand gets super excited and is slightly faster than my left knee/ankle/foot.</TD></TR></TABLE>
you don't have a short shifter do you?
i have that axial one ricks makes, but i think im gong to take it out and put the OEM one back in.
i need to purchase an ETD soon to see what its like.
Old May 5, 2006 | 10:53 AM
JDM knowledge's Avatar
Default Re: (vapor)
i would think there wouldnt be any negativ effects. unless you dont link a slight stiffer ride.
Old May 5, 2006 | 11:09 AM
Mr. Projekt's Avatar
* B A N N E D *
The damper does not raise hp/tq settings, it gives better response from the output shaft to the wheels by taking away the flex/stress put on the motor mounts.
Negs: Strut tower flexing from the extra torque. An STB would be needed in this case.
Old May 5, 2006 | 11:14 AM
Luder94's Avatar
Default Re: (Francesco)
Nope...no short shifter. I don't need anything shorter on the S2000 than what comes stock. I'd hate to lose that feel for each distinctive gear. I've driven cars with the Axial and the Distincto Bellino short shifter...it's just not for me. I don't save anymore time in shifts, nor do I need to. Me getting to my friends' homes .32432 seconds earlier in my short-shifting s2000 isn't a priority.
Old May 5, 2006 | 11:23 AM
evil vapor's Avatar
Default Re: Engine damper (FR-MOB: Projekt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FR-MOB: Projekt &raquo;</TD></TR><TR><TD CLASS="quote">The damper does not raise hp/tq settings, it gives better response from the output shaft to the wheels by taking away the flex/stress put on the motor mounts.
Negs: Strut tower flexing from the extra torque. An STB would be needed in this case.</TD></TR></TABLE>
The engine would have to produce over 500lb/ft of torque running a triple plate clutch and slicks launching at a drag strip to flex the passenger strut tower running a ETD. At that point, you'd be flexing the chassis anyways, fast and furious style!
Old May 5, 2006 | 11:26 AM
* B A N N E D *
Default Re: Engine damper (vapor)
I'd get one though.. I'd seen my motor move quite a bit.
Old May 16, 2006 | 06:44 AM
djnikko's Avatar
Is it worth having an engine damper both sides? Has anyone done this?
Thanks
Old May 16, 2006 | 07:20 AM
blkturbos2k's Avatar
Default Re: Engine damper (evil vapor)
I made 300lbs on pump gas and low boost. I dont know if I will get to 500lbs but i should be close
Old May 16, 2006 | 12:27 PM
evil vapor's Avatar
Default Re: Engine damper (djnikko)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djnikko &raquo;</TD></TR><TR><TD CLASS="quote">Is it worth having an engine damper both sides? Has anyone done this?
Thanks </TD></TR></TABLE>
No, the engine torques only one way, unless you plan on racing in reverse.
Old May 16, 2006 | 12:57 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evil vapor &raquo;</TD></TR><TR><TD CLASS="quote">No, the engine torques only one way, unless you plan on racing in reverse. </TD></TR></TABLE>
lol.
Old May 16, 2006 | 04:22 PM
Infinity_Racer's Avatar
Default Re: Engine damper (JDM knowledge)
if you want something cheaper the NRG engine damper is only 75 bucks at http://www.s2kaccessories.com/enginedampers.html
GBRacing
34
Feb 3, 2010 12:03 AM
ragerized
May 20, 2004 12:32 PM
Red AEM Civic
Feb 5, 2004 04:02 AM
Steve91
Aug 24, 2003 09:13 AM
WAFFLES
37
Aug 6, 2003 03:41 PM
