Honda S2000 Honda S2000
Electricity Issues...
Old Oct 15, 2008 | 04:50 PM
ReddotsS2K's Avatar
Default Electricity Issues...
Yesterday i was driving my car when i stopped at a redlight, and noticed that every 4 seconds or so the idle would shoot up and i would hear a click under the hood. I immediately got it home and looked under the hood...did not see anything obvious. So i went to go start the car again and it would...almost as if the battery were dead. It has the slow and long cranking sound. So i went in the house for an hour or so, came back out and it cranked right up. Well i parked her and decided to pull her out again tonight....not whenever this problem happens at idle my radio shuts off, my gauge cluster lights shut off, and the eps light flickers.
any ideas? I am going to replace tha alternator, the lights in the car have been sort of flickering for a while and hopefully that is it. Has anyone seen this before though?
I recorded it on camera yesterday and i will upload it to youtube i suppose.
Old Oct 15, 2008 | 05:12 PM
ReddotsS2K's Avatar
Default Re: Electricity Issues... (ReddotsS2K)
here is the vid i took...when it first started...not the eps light is coming on whenever it does it, along with the radio going on the fritz and the instrument cluster flickering..
http://www.youtube.com/watch?v=RLE5MvElkgU
Old Oct 15, 2008 | 05:33 PM
marty's Avatar
That reminds me of driving my friends Impreza RS. It seems like an alternator problem.
Old Oct 16, 2008 | 07:22 AM
White Smoke's Avatar
i my honda
Global Mod
It sounds like a problem with your alternator. Check and make sure you have a good connection between the alternator and the battery. As well as the alternator to fuse box. Maybe one of those wires is lose. If not you have a bad alternator.
Old Oct 16, 2008 | 07:31 AM
Chris.'s Avatar
Honda-Tech Order of Merit
Default Re: Electricity Issues... (White Smoke)
im with them above, its most likely your alternator
Old Oct 16, 2008 | 08:17 AM
wjkj08's Avatar
Sick car :D
Old Oct 16, 2008 | 08:30 AM
ReddotsS2K's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Smoke &raquo;</TD></TR><TR><TD CLASS="quote">It sounds like a problem with your alternator. Check and make sure you have a good connection between the alternator and the battery. As well as the alternator to fuse box. Maybe one of those wires is lose. If not you have a bad alternator.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris. &raquo;</TD></TR><TR><TD CLASS="quote">im with them above, its most likely your alternator</TD></TR></TABLE>
I believe you guys are correct...i hooked some jumpers up to it from the jetta and left the jetta running and the problem went away. I have a lifetime replacement on the alternator (advanced aut parts) so i am going to swap it out when i have some time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wjkj08 &raquo;</TD></TR><TR><TD CLASS="quote">Sick car :D</TD></TR></TABLE>
thank you sir
Old Oct 30, 2008 | 10:03 AM
S2Kguy512's Avatar
Was that the problem?
Today I noticed that when the car's rpms go down and it starts to idle my radio cuts on and off and the EPS/Gauge cluster flickers.
I started the car up and undid the battery to see if the car dies but it didn't so perhaps the alternator is not on it's last leg just yet?? I hope it's the problem and not some other dumb electrical issue.
Will take the autozone for an alternator test to verify.
Thanks in advance.
Old Oct 30, 2008 | 11:25 AM
ReddotsS2K's Avatar
Default Re: Electricity Issues... (S2Kguy512)
yes, it was the alternator. My alternator took a while to go though...it started off with my tailights and gauge cluster flickering and then got worse.
Mine was at about the same stage yours is, it never got to the point where the car would shut off, but it was close. Seems as if it just wasn't pumping out enough electricity, but enough to barely get by.
Old Oct 30, 2008 | 01:40 PM
bigmacnfries's Avatar
I still laugh out loud at your PA system vid on youtube!
funny $hit dude..
Old Oct 30, 2008 | 02:03 PM
S2Kguy512's Avatar
Turns out my battery was dead only after 2 years. I was told the alternator was still good.
The battery had no charge... best part was it was still under warranty so it was a free replacement from AutoZone.
Still a little bit worried since I've never seen the EPS or gauge cluster flicker from my previous OEM battery going dead ... but all is good now.
Thanks again.
Old Oct 30, 2008 | 03:57 PM
ReddotsS2K's Avatar
Default Re: Electricity Issues... (bigmacnfries)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigmacnfries &raquo;</TD></TR><TR><TD CLASS="quote">I still laugh out loud at your PA system vid on youtube!
funny $hit dude..
I will have a sequal coming soon with driving through a neighborhood...with kids running out and not seeing the icecream truck and getting all upset...and their parents cussing. I should of made a vid of it when it was warm out...maybe this weekend
when i shoot it i will post it up
ReddotsS2K's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2Kguy512 &raquo;</TD></TR><TR><TD CLASS="quote">Turns out my battery was dead only after 2 years. I was told the alternator was still good.
Thanks again. </TD></TR></TABLE>
ah, so your battery must have not been able to recharge. glad you figured it out and it was no cost to you
Boosted EJ2
Feb 6, 2011 11:43 AM
97dxnut
12
Mar 4, 2005 05:44 PM
spoonef
10
Jul 15, 2003 06:55 PM
dragtaccord
Nov 8, 2002 01:41 PM
carsaregood
Sep 9, 2002 02:30 PM
