Honda S2000 Honda S2000
drop spring/toe question
Old Mar 28, 2005 | 12:59 PM
Moemers's Avatar
Default drop spring/toe question
ok, no one answers me on s2ki, maybe you guys can help
i am looking to buy koni yellows and some drop springs for my s2000, but at the same time i talked to my friend and he told me that when rear wheel drives are dropped toe becomes an issue. so my question is 2 parts: what springs do you recommend with the koni yellows (im looking for 1 inch max) and how do i go about fixing the toe problem, as i understand that camber/caster can be adjusted rather easily?
Old Mar 28, 2005 | 01:01 PM
Francesco's Avatar
Default Re: drop spring/toe question (RWD_Honder)
a good alignmet should fix it, and i think the toe can be adjusted...
as for springs, i would look into the espeliers...
Old Mar 28, 2005 | 01:05 PM
Moemers's Avatar
Default Re: drop spring/toe question (Francesco)
i was looking toward the Tein's actually...
Old Mar 28, 2005 | 01:10 PM
Francesco's Avatar
tein s tech springs should work...
IMO i would get coilovers. I love my tein flex, and you have the ease to adjust the height...
Old Mar 28, 2005 | 01:12 PM
SuzukaBlueAP2's Avatar
Toe, camber, and caster can be problems on all lowered vehicles, regardless of their engine placement and drivetrain.
They can also all be corrected by a good alignment shop. Once the drop is done, go get an alignment. They'll tell you how far out of specs your are. And, in some cases, they'll be able to fix it. In some extreme cases, say -5.0 degrees of camber, you may need a camber correction kit.
kraaaaap
20
Jul 6, 2007 09:14 AM
guero2craze
Jan 8, 2007 06:54 AM
1sckcvc
Jul 6, 2006 08:02 PM
RacerBoy
Sep 25, 2002 10:39 AM
