Honda S2000 Honda S2000
Differential Fluid recommendations?
Old May 14, 2003 | 10:05 PM
Lunacy's Avatar
Default Differential Fluid recommendations?
now I can get my hands on Motul 75w-90 and Redline 75w-90
Does anyone have any experience with them?
which one should I go with?
thanks for your input.
Old May 15, 2003 | 12:15 AM
Schatten's Avatar
Default Re: Differential Fluid recommendations? (Lunacy)
swepco 201. trust me on this. the redline stuff, sure, a good oil but the swepco 201 rocks in the s2000 diff.
Old May 15, 2003 | 07:44 AM
Razor's Avatar
Default Re: Differential Fluid recommendations? (Schatten)
where can you get it from?
Old Nov 14, 2004 | 09:46 AM
92jdmhatch's Avatar
Default Re: Differential Fluid recommendations? (Razor)
my s2000 is a 2000 and i bearly hit 30k miles on there today....i am considering going with the swepco 201......i found many sites that sell it for 42.94 or so..it said something about 80w90.... is the the one i am looking to get? also i am considering change my rear diff...and getting a new clutch...any suggestions on whether or not to wait and get the clutch and diff then switch to swepco 201 or just put it in there anyway?
Old Nov 14, 2004 | 01:13 PM
evil vapor's Avatar
Default Re: Differential Fluid recommendations? (92jdmhatch)
I've used Swepco before and wasn't "thrilled." Mobil 1 syn gear fluid works well, is affordable, and is easy to get.
Old Nov 15, 2004 | 06:29 PM
CWESTINAP1's Avatar
redline has been proven to show wear on s2000's after just a short amount of driving.
I'm using Almasol and it feels great.
Old Nov 15, 2004 | 06:56 PM
Nishant's Avatar
Default Re: Differential Fluid recommendations? (CWESTINDC2)
Lubrication Engineers LE-607 90W Almasol Gear Oil is what I use
Old Nov 15, 2004 | 10:10 PM
Razor's Avatar
Default Re: Differential Fluid recommendations? (vapor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vapor &raquo;</TD></TR><TR><TD CLASS="quote">I've used Swepco before and wasn't "thrilled." Mobil 1 syn gear fluid works well, is affordable, and is easy to get. </TD></TR></TABLE>
i agree. it's found at most automotive parts stores and is only 8-9 bucks.
Old Nov 16, 2004 | 07:18 AM
Ferrell's Avatar
mobil 1 here
Old Nov 16, 2004 | 05:59 PM
VTECorona's Avatar
Default Re: Differential Fluid recommendations? (Nishant)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nishant &raquo;</TD></TR><TR><TD CLASS="quote">Lubrication Engineers LE-607 90W Almasol Gear Oil is what I use</TD></TR></TABLE>
, the s2ki guys swear by it. I'd say go with either Mobil1 or the LE. The mobil1 is much easier to get as vapor already said.
Old Nov 16, 2004 | 11:26 PM
Dr.K's Avatar
And Imperial Oil Owns Mobil 1. How can you mess with a company that can throw Multi-Millions into Research and Development? Amsoil is some little company in the states.I dont' know about Motul. Imperial Oil makes a billion a year in profit and can spend big money on research. And if Amsoil or Motul was better wouldn't Sportscars roll out from the factory with it? Porsche's and Vette's roll out of the factory with Mobil 1. Nuff' said.
Old Nov 16, 2004 | 11:46 PM
evil vapor's Avatar
Default Re: (Dr.K)
this is where I'll say, whatever makes you sleep easier at night
Old Nov 17, 2004 | 02:32 AM
TommyV's Avatar
Default Re: (vapor)
Hey Vapor
What about LE 602??????
Old Nov 17, 2004 | 03:35 AM
fperra's Avatar
Default Re: (TommyV)
"And Imperial Oil Owns Mobil 1. How can you mess with a company that can throw Multi-Millions into Research and Development? Amsoil is some little company in the states.I dont' know about Motul. Imperial Oil makes a billion a year in profit and can spend big money on research. And if Amsoil or Motul was better wouldn't Sportscars roll out from the factory with it? Porsche's and Vette's roll out of the factory with Mobil 1. Nuff' said."
You learn something new every day. And to think I thought Exxon Mobil owned Mobil 1?? I'm probably wrong in thinking that Exxon Mobil owns Imperial too.
Old Nov 17, 2004 | 05:54 AM
Be3LiCiOuS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vapor &raquo;</TD></TR><TR><TD CLASS="quote">Mobil 1 syn gear fluid works well, is affordable, and is easy to get. </TD></TR></TABLE>
agreed
Old Nov 17, 2004 | 12:25 PM
1.8t's Avatar
Default Re: Differential Fluid recommendations? (Be3LiCiOuS)
Mobil 1 here as well.
Old Nov 17, 2004 | 07:58 PM
Razor's Avatar
Default Re: (vapor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vapor &raquo;</TD></TR><TR><TD CLASS="quote">this is where I'll say, whatever makes you sleep easier at night</TD></TR></TABLE>
good call. people will start chopping eachothers heads off due to oil disputes.
Old Nov 17, 2004 | 09:29 PM
Dr.K's Avatar
Default Re: (Razor)
Ya Im an Idiot...it is Exxon...Hell there only is like 3 Big major Oil companies anyways. Just stick with the Mobil 1.
Old Nov 22, 2004 | 08:00 PM
evil vapor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TommyV &raquo;</TD></TR><TR><TD CLASS="quote">Hey Vapor
What about LE 602??????</TD></TR></TABLE>
I dunno, never tried it but my friend that does the gear swaps and LSD installs says that LE stuff is THICK! I've never had any problems running the mobil 1 on the track nor on the streets so why try something else? There's no such thing as a magical diff fluid, and for sunny so cal, I don't need stuff that works in really cold weather.
Old Nov 22, 2004 | 08:05 PM
evil vapor's Avatar
Default Re: (Razor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Razor &raquo;</TD></TR><TR><TD CLASS="quote">
good call. people will start chopping eachothers heads off due to oil disputes.</TD></TR></TABLE>
you forgot to add, no pun intended
Old Nov 23, 2004 | 05:12 PM
TommyV's Avatar
Default Re: (vapor)
I dunno, never tried it but my friend that does the gear swaps and LSD installs says that LE stuff is THICK! I've never had any problems running the mobil 1 on the track nor on the streets so why try something else? There's no such thing as a magical diff fluid, and for sunny so cal, I don't need stuff that works in really cold weather. </TD></TR></TABLE>
Sounds good to me........... I guess it really does come down to what brand the individual is most comfortable with.
I won't use anything but Castrol Syntec 10w 30 or 5w 30 in my engines - and no one can tell me otherwise, but again, that's just my crazy feeling that Castrol is excellent oil.
Old Nov 27, 2004 | 02:15 PM
oakfloor's Avatar
hi just got here, checkout the s2ki site. theres a great thread on oils of all kinds. its called the "oil journals" drive safe.
Old Nov 27, 2004 | 06:24 PM
evil vapor's Avatar
Default Re: Differential Fluid recommendations? (oakfloor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oakfloor &raquo;</TD></TR><TR><TD CLASS="quote">
hi just got here, checkout the s2ki site. theres a great thread on oils of all kinds. its called the "oil journals" drive safe.</TD></TR></TABLE>
awesome
Old Nov 27, 2004 | 08:40 PM
oakfloor's Avatar
yeah, Im really sold on the amsoil 10w-30. and will be useing LE607 for my next diff oil change out. glad you liked it.
Old Nov 27, 2004 | 09:20 PM
soundzero's Avatar
Well, I am currently using LE607 diff oil. Difference? Not sure.
But it was recommanded by several other owners so I went with it.
Now, transmission oils in other hand, GMFMSM oil was big change from OEM.
