Honda S2000 Honda S2000
Comptech adjustable springs PROBLEM... please look!
Old Jun 2, 2005 | 05:48 PM
NomiAP1's Avatar
Default Comptech adjustable springs PROBLEM... please look!
Hey guys, i have a MY01 s2000 and had just purchased some comptech adjustable springs ( http://www.comptechusa.com/instructions/ins061.pdf this is a pdf file from comptech’s website that instructs you on how to install the springs.) and I installed them exactly how the instructions from comptech’s website says.
The car is lowered 2.5 inches and it rides really nice, but the thing that is concerning me is a popping noise coming from the rear end of the car, it almost sounds like the shock is popping out of place, but the ride is still the same no loss in acceleration or deceleration and it handles the same if not better than stock, its just that popping noise that is very disturbing.
It happens at every bump and sometimes even randomly. Any suggestions? Its been raining a lot here lately and I've known that the rotors create surface rust very easily which sometimes sticks to the brake pad, so when you move it pops the seal or whatever.
TIA,
-Nomi
Modified by imon at 6:59 PM 6/2/2005
Old Jun 2, 2005 | 06:07 PM
fknfast's Avatar
Default Re: Comptech adjustable springs PROBLEM... please look! (imon)
make sure everything is tight!
Old Jun 2, 2005 | 06:27 PM
cmdr430's Avatar
2.5 is lowered quite a bit.....
it may be putting to much strain on the drive shaft (drivetrain) components........
the same happens when you raise a truck to high.... it puts strain on the drive shaft and could cause it to fail...... you have to lengthen them sometimes....
when you lower the car that much the shaft is pushing back against the rearend (differential) more, and could be causing undo strain on it......
just my thoughts.....
Modified by cmdr430 at 10:41 PM 6/2/2005
Old Jun 2, 2005 | 07:17 PM
NomiAP1's Avatar
Default Re: Comptech adjustable springs PROBLEM... please look! (cmdr430)
yeah i was going to try to raise it tomorrow to see if it changes anything so we'll see...
Old Jun 2, 2005 | 07:30 PM
Mr. Bagel's Avatar
all I can suggest is you torque everything down when it isn't under load.
since these have adjustable perches, you should go for a corner balance and alignment to make it worth the investment. if you need further info, just ask.
Old Jun 2, 2005 | 07:39 PM
revhi's Avatar
I had them on my car originally, than I just put them on my girls S. Shes pretty slammed with no problems. Did you cut the bumpstops?
Old Jun 2, 2005 | 07:44 PM
NomiAP1's Avatar
Default Re: (revhi)
yes i cut the rear bump stomps by accident, but the fronts were left stock, but i doubt the bumpstops would make that noise? and i cut it in half so there is a lot of the bump stop still left....
Old Jun 2, 2005 | 09:24 PM
Nishant's Avatar
Default Re: (imon)
i would make sure everything is torqued down properly. if the noise continues, it is prob putting too much stress on your already worn down cv joint
Old Jun 4, 2005 | 09:57 AM
NomiAP1's Avatar
Default Re: (Nishant)
well i raised the car about 1 inch but its still making that noise, i also posted this on s2ki.com and someone said something abou the bulljoints on the sway bar being loose? i know the top bulljoint just spins on the passenger side of the car and all the other bolts for the sway bar are tight? anyone have any tips on how to tighthen this bolt? because this could be the answer to my problem...
acuraLSSE95
May 16, 2005 07:23 PM
kseriesDC5
Jun 15, 2004 11:32 AM
teg2lose2
Acura TL, RL & ZDX
Dec 2, 2003 05:18 PM
BerlinaAP2
Apr 15, 2003 06:00 PM
00VTEC
Oct 25, 2001 09:21 PM
