Honda S2000 Honda S2000
Which coilovers
Old Aug 31, 2004 | 09:02 AM
AWDBall2.0's Avatar
Default Which coilovers
I'm looking to get some coilovers but wanted to see what most people are using. I like the Tein setup but don't know if there's something that would work better on the S2k. Any info would help, thanks in advance.
Old Aug 31, 2004 | 09:06 AM
Mr. Bagel's Avatar
Default Re: Which coilovers (AWDBall2.0)
There's always something that will work better. But it all depends on your budget and the intended purpose. If you are just driving on the street and an occassional autocross, stock or even ground control with konis/eibachs will work fine for the dollar.
Old Aug 31, 2004 | 10:29 AM
AWDBall2.0's Avatar
Street and the occasional auto-x would probably be the extent of what I'd use it for but I want to make sure I do it right, I'm tired of having to redo things b/c I didn't save an extra couple $100, money doesn't matter. Thanks for the info...any other suggestions as to what has worked well.
Old Aug 31, 2004 | 12:57 PM
AWD: Jeff's Avatar
it depends if your a hardcore track person. if your not going to do any serious racing go with somthing more wallet friendly. i do not track my car and i decided to go with koni yellows and kgmm springs, although i want adjustability i am going with gc w/ custom rate springs. imo i think tien is just jdm bling.
Old Aug 31, 2004 | 01:04 PM
alex_b's Avatar
Tein is kinda of just thrown together. their lack of quality shows in their product. they're not highly regarded amongst real track addicts.
the ultimate would be JRZs, Toda/Fightex, or Amuse Hi-Tech Dampers.
i myself am going for GP Sports, reasonable price, good all around performance, not 3 grand like the above mentioned. heh
Old Aug 31, 2004 | 02:33 PM
The Tea-father's Avatar
Default Re: Which coilovers (alex_b)
i'm very happy with the jic flta2, i have it on all of my cars, i don't have any problem with it at all. the ride quality is a little stiff.
Old Aug 31, 2004 | 08:04 PM
evil vapor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AWDBall2.0 &raquo;</TD></TR><TR><TD CLASS="quote">Street and the occasional auto-x would probably be the extent of what I'd use it for but I want to make sure I do it right, I'm tired of having to redo things b/c I didn't save an extra couple $100, money doesn't matter. Thanks for the info...any other suggestions as to what has worked well. </TD></TR></TABLE>
run stock, I shaved an average of 2 seconds off my lap times after selling my Tein RS's. Auto-x times improved too. Car is easier to drive.
Old Aug 31, 2004 | 08:37 PM
Mr. Bagel's Avatar
Default Re: Which coilovers (vapor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vapor &raquo;</TD></TR><TR><TD CLASS="quote">run stock, I shaved an average of 2 seconds off my lap times after selling my Tein RS's. Auto-x times improved too. Car is easier to drive. </TD></TR></TABLE>
*thumbs up*
stiffer does not mean it handles better. you actually reduce the turn in rate quite a bit.
Old Aug 31, 2004 | 08:44 PM
Project SSAP1's Avatar
id say for go either H&R or bilstein PSS or PSS9...these are a lil stiffer than stock...and have the adjustable hieght....IMO great for everyday driving and some track sessions... ....if i had the doe id be all over the H&R PSS9...similar to the amuse setup
Old Sep 1, 2004 | 10:44 AM
AJ PwR's Avatar
I remember seeing the JIC dyno test at the ITR forum and the tunability range is not great and they over heat very easily.
Old Sep 1, 2004 | 10:53 AM
tmkpres's Avatar
Default Re: Which coilovers (fd3st04r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fd3st04r &raquo;</TD></TR><TR><TD CLASS="quote">i'm very happy with the jic flta2, i have it on all of my cars, i don't have any problem with it at all. the ride quality is a little stiff.</TD></TR></TABLE>
Ive heard that their struts tend to blow
Old Sep 1, 2004 | 01:34 PM
SPOONup's Avatar
Thanks for the info,I'll keep the car stock for awhile and learn how to best drive it and then look at my options and what would best suit my needs. Thanks agian for the info.
Old Sep 1, 2004 | 07:52 PM
medicalstudent's Avatar
Stock works great. I went stock for 2 years before throwing on some Mugen NZ coilovers.
Old Sep 1, 2004 | 07:53 PM
eboixing's Avatar
Default Re: (medicalstudent)
d2's
loud&proud_ej1
Suspension & Brakes
Nov 21, 2013 09:38 AM
SD_smrk1
Nov 9, 2007 09:56 PM
jdm_r1
Suspension & Brakes
Apr 10, 2007 01:44 PM
JDMJunior
Dec 8, 2005 10:01 AM
1SLOWlsTEG
Feb 21, 2005 07:47 PM
