Honda S2000 Honda S2000
clutch NEED HELP
Old Nov 17, 2007 | 08:07 AM
matthevelli's Avatar
Default clutch NEED HELP
alrigght guys, 2002 s2000..im replacing the clutch so far its been pretty easy (minus that top starter bolt..what a basterd) anyway i know you have pull the bearing fork out a little so the trans comes of the engine..dudes..it wont budge..anyone have this problem and any tips..thanks.
Old Nov 17, 2007 | 10:05 AM
fridaytech's Avatar
Default Re: clutch NEED HELP (matthevelli)
the release bearing fork is just held in by wedge type bracket. push trans all the way in towards engine. grab release fork and pull. sucker should pop out and sit down out of the way.
Old Nov 17, 2007 | 10:20 AM
ReddotsS2K's Avatar
remember this when ur putting it back on too. your right that starter bolt was a bitch.
did you take your headers off or anything?
Old Nov 17, 2007 | 11:31 AM
Default Re: clutch NEED HELP (ReddotsS2K)
yeah everything is off..including header..its really not that bad of a job im diong it at work with air tools and a lift..and tranny jacks ...i cant amagine doing it on my garage floor...anyways im thinking i should of pulled the fork out first before i took it off the aligning dowl pins..but i;ll get it aligned again put a coiuple bolts in and try to move the fork..thanks for you help.
eghatchfla
Jul 24, 2010 10:57 AM
black94lude
Jul 19, 2009 11:09 AM
quicksilver1689
Oct 10, 2006 11:30 PM
EF-Honda91
Sep 12, 2006 11:13 AM
a1320addict
May 29, 2005 07:17 AM
