Honda S2000 Honda S2000
clunking noise HELP....
Old Oct 19, 2004 | 12:59 PM
mstyper's Avatar
Default clunking noise HELP....
I have a quick question for all of you a buddy of mine has a S2000, and when he is turning either right to left at slow speeds he hears what would be a loud clunking noise from the rear of the car.. It shakes the whole car... It only does it when his foot is off the gas. He had the LSD changed out and that did not fix it... The only mod on the car is it is lowered, but the car was lowered for some time now so I feel that this is not the reason for the clunking noise... when putting in the New LSD to try and fix the problem every nut and bolt was torqued to Honda specks.. And yes we doubled checked them already... He had a shop take it out and put it back it to make sure we did it right. If any one knows what could be wrong please help me out I am at a loss. I can only think of one more thing that could be causing it and I would like to here what you all think before I go about doing it. I am with holding what I feel could be the problem do to the fact I feel that some one might say "yes that is the problem and then every one else will say the same thing"..
If any one can think of any thing please let me know.
Thanks,
Old Oct 19, 2004 | 04:59 PM
ImportSport's Avatar
Visit http://www.s2ki.com and post this in the under the hood section.
Old Oct 19, 2004 | 10:24 PM
evil vapor's Avatar
Default Re: (ImportSport)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ImportSport &raquo;</TD></TR><TR><TD CLASS="quote">Visit http://www.s2ki.com and post this in the under the hood section.</TD></TR></TABLE>
or you can help the guy out rather than telling him to go elsewhere
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mstyper &raquo;</TD></TR><TR><TD CLASS="quote">I have a quick question for all of you a buddy of mine has a S2000, and when he is turning either right to left at slow speeds he hears what would be a loud clunking noise from the rear of the car.. It shakes the whole car... It only does it when his foot is off the gas. He had the LSD changed out and that did not fix it... The only mod on the car is it is lowered, but the car was lowered for some time now so I feel that this is not the reason for the clunking noise... when putting in the New LSD to try and fix the problem every nut and bolt was torqued to Honda specks.. And yes we doubled checked them already... He had a shop take it out and put it back it to make sure we did it right. If any one knows what could be wrong please help me out I am at a loss. I can only think of one more thing that could be causing it and I would like to here what you all think before I go about doing it. I am with holding what I feel could be the problem do to the fact I feel that some one might say "yes that is the problem and then every one else will say the same thing"..
Thanks, </TD></TR></TABLE>
Has your axles, specifically the CV joints been checked? On a lowered car, there is a tendency for accelerated wear in the driver side inner CV joint. That should be the source of your problem.
Old Oct 20, 2004 | 03:50 AM
mstyper's Avatar
Default Re: (vapor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vapor &raquo;</TD></TR><TR><TD CLASS="quote">
Has your axles, specifically the CV joints been checked? On a lowered car, there is a tendency for accelerated wear in the driver side inner CV joint. That should be the source of your problem. </TD></TR></TABLE>
That is what I was thinking we are going to look at this weekend....
Thanks,
Is there any thing else you can thinl of off the top of your head??
Old Oct 20, 2004 | 11:01 AM
evil vapor's Avatar
Default Re: (mstyper)
Thanks,
That's all I can think of. If you hear the sound while turning both left and right, chances are both sides need inspection/repair/replacement. If only one side, well, you'll know. Good luck!
Old Oct 20, 2004 | 11:35 AM
WowOzYouRock's Avatar
Default Re: clunking noise HELP.... (mstyper)
check the sway bar bushing too while ur at it cuz same thing happen to my civic...
Old Oct 20, 2004 | 01:19 PM
mstyper's Avatar
Default Re: clunking noise HELP.... (Y2K_S2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Y2K_S2K &raquo;</TD></TR><TR><TD CLASS="quote">check the sway bar bushing too while ur at it cuz same thing happen to my civic...</TD></TR></TABLE>
Will do thanks
Old Oct 20, 2004 | 02:37 PM
Chillinlikeamofo's Avatar
You're comparing a civic to an S2000?!?! OMG you're killing me
Old Oct 20, 2004 | 03:44 PM
evil vapor's Avatar
Default Re: clunking noise HELP.... (Chillinlikeamofo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chillinlikeamofo &raquo;</TD></TR><TR><TD CLASS="quote">
You're comparing a civic to an S2000?!?! OMG you're killing me </TD></TR></TABLE>
he's not comparing, he simply suggested another place where there might be binding/noise.
Old Oct 20, 2004 | 03:52 PM
Ahhvtec1's Avatar
Default Re: (vapor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">or you can help the guy out rather than telling him to go elsewhere </TD></TR></TABLE>LMAO @ Vapors!
Old Oct 21, 2004 | 03:03 PM
LOL ... did he just tryna flame me? hahaha .... nice try 26 yrs old newbie
Old Oct 21, 2004 | 04:00 PM
evil vapor's Avatar
Default Re: (Ahhvtec1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ahhvtec1 &raquo;</TD></TR><TR><TD CLASS="quote">LMAO @ Vapors! </TD></TR></TABLE>
tonyle789
Transmission & Drivetrain
13
Mar 19, 2012 10:14 AM
BEESTA
Apr 21, 2008 02:18 PM
Missing_In_Action
Apr 5, 2008 03:19 PM
_RedRiceR_
Jun 19, 2006 12:59 AM
SleepnCiViC
Feb 2, 2004 12:36 PM
