Honda S2000 Honda S2000
Changing rear diff fluid?
Old Apr 4, 2004 | 05:58 AM
nutsack's Avatar
Default Changing rear diff fluid?
How many of you have changed your rear diff fluid? if so what did you use and how much, i know honda does car s2000 rear diff fluid. also what are the recommended change intervals, 15k or 30k?
Old Apr 4, 2004 | 12:39 PM
evil vapor's Avatar
Default Re: Changing rear diff fluid? (*******)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ******* &raquo;</TD></TR><TR><TD CLASS="quote">How many of you have changed your rear diff fluid? if so what did you use and how much, i know honda does car s2000 rear diff fluid. also what are the recommended change intervals, 15k or 30k?</TD></TR></TABLE>
depending on how you drive it. I would change it no longer than 15k miles if the car was driven very lightly and every other oil change if the car was a daily driver. Mobil 1 synthetic gear oil is the best bang for the buck while the redline race fluid is just that, race stuff that should be replaced frequently.
Old Apr 4, 2004 | 06:12 PM
nutsack's Avatar
Default Re: Changing rear diff fluid? (vapor)
what weight gear oil?
Old Apr 4, 2004 | 06:29 PM
evil vapor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ******* &raquo;</TD></TR><TR><TD CLASS="quote">what weight gear oil?</TD></TR></TABLE>
90 wt, or a syn blend of 75/90
Old Apr 5, 2004 | 02:37 AM
TommyV's Avatar
I'm too lazy to look in my service manual, but do you need a way to "pump" the fluid into the rear diff (and the transmission as well)?
My S is in dire need of fluid replacement, and I don't have access to a lift.
Old Apr 5, 2004 | 11:54 AM
evil vapor's Avatar
Default Re: Changing rear diff fluid? (TommyV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TommyV &raquo;</TD></TR><TR><TD CLASS="quote">I'm too lazy to look in my service manual, but do you need a way to "pump" the fluid into the rear diff (and the transmission as well)?
My S is in dire need of fluid replacement, and I don't have access to a lift. </TD></TR></TABLE>
yep, a nice little hand pump makes the job easier.
Old Apr 5, 2004 | 12:02 PM
BANting's Avatar
heres a write up
http://forums.s2ki.com/forums/...99995
Old Apr 5, 2004 | 12:13 PM
Razor's Avatar
Default Re: Changing rear diff fluid? (oNE.five ray)
i change my transmission and differential fluids once a year. it's cheap insurance, why not?
for the diff.: mobil 1 75w90(you only need one bottle, it will probaly only use 3/4 of it)
for the tranny: honda mtf, you only need 2 bottles(probably uses around 1.25-1.5)
just fill up until the fluid starts pouring out of the fill hole.
Old Apr 5, 2004 | 05:19 PM
TommyV's Avatar
Default Re: Changing rear diff fluid? (Razor)
excellnt, thanks guys!
codysam
Aug 20, 2017 07:44 AM
hieu512
Honda S2000
31
Nov 10, 2007 08:57 PM
TopNotchR
Sep 24, 2004 06:50 PM
Razor
Honda S2000
13
Sep 18, 2003 02:16 PM
