Honda S2000 Honda S2000
car pulling to the right and left
Old Oct 26, 2006 | 10:12 AM
yellow_s2k_1's Avatar
Default car pulling to the right and left
when im driving my car pulls to the right while acceleration and left when decelaration has any of u had that problem before?
Old Oct 26, 2006 | 10:29 AM
LAS2K's Avatar
Default Re: car pulling to the right and left (yellow_s2k_1)
this happens like every week to somebody...
check for a nail or something in the tire or your tire pressure.
Old Oct 26, 2006 | 10:37 AM
gomarlins3's Avatar
Best case- tire pressure difference in the rears.
Mid case- different tire construction in the rears.
Worse case- diff going out.
I have had to deal with 'best' and 'mid' and hope to never have to deal with 'worse'.
Old Oct 26, 2006 | 10:47 AM
Default Re: (gomarlins3)
well i do have a nail in the tire but naver lost air pressure also i have comptech coilovers i took it to an alingment shop and they told me it didnt need one that the car drove straight felt fine is because of the power that the car has should i go somewhre else. i talk to the honda dealership an they told me it has to be a differencial problem what do u guys think ...
Old Oct 26, 2006 | 07:09 PM
Francesco's Avatar
Default Re: (yellow_s2k_1)
if your tire pressure is fine, the next step is to get an alignment.
Old Oct 26, 2006 | 10:18 PM
LAS2K's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellow_s2k_1 &raquo;</TD></TR><TR><TD CLASS="quote">well i do have a nail in the tire but naver lost air pressure also i have comptech coilovers i took it to an alingment shop and they told me it didnt need one that the car drove straight felt fine is because of the power that the car has should i go somewhre else. i talk to the honda dealership an they told me it has to be a differencial problem what do u guys think ...</TD></TR></TABLE>
DOHH. still doesn't matter. replace the tire and this thread is over with.
Old Oct 28, 2006 | 08:55 AM
B18c1vicrx's Avatar
it happened to me buyt i had two different brand tires when i bought it.
that was my problem so check your tires!!!!!11
Old Oct 28, 2006 | 01:43 PM
negcamber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellow_s2k_1 &raquo;</TD></TR><TR><TD CLASS="quote">well i do have a nail in the tire but naver lost air pressure </TD></TR></TABLE>
I take it this means you have checked it recently (as in every day). As the nail wears down the leak can get worse.
What you describe sounds like what we have all experienced at one time or another and is usually tire pressure related.
However...since you have coilovers...the problem can also be that you have a perch that is not at the same height as its pair. Or, if you have adjustable shocks, then your shock settings might be uneven. Or it can be alignment...just because it tracks straight does not mean the alignment is right...you could have toe way out of adjustment (which can cause the problem you describe), or uneven camber settings.
EJ8VTECFTW
Honda Civic (2006 - 2015)
Jul 10, 2007 08:15 PM
jamsicle
Honda S2000
Oct 11, 2006 09:20 AM
BDogggUT34
Nov 28, 2005 10:39 AM
nsxtasy
Sep 14, 2005 04:50 PM
slash00R
Jan 23, 2002 06:04 PM
