Honda S2000 Honda S2000
caged s2000
Old Mar 7, 2005 | 04:31 AM
  #26
blues2k3's Avatar
Default Re: (stormy)
you are absolutely correct...with a few passes on the previous setup you do begin to notice slight buzz from the diff.
Old Mar 7, 2005 | 06:41 PM
  #27
honda9krpm's Avatar
Default Re: (blues2k3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blues2k3 &raquo;</TD></TR><TR><TD CLASS="quote">We have run high 11s with a 1.8 60ft on the stock diff with drag radials. The new diff will run 3.90 gears is a one off capable of holding the power...a slightly modified verison of those seat are being used so the cage was built around the proper dimenson. </TD></TR></TABLE>
that's a very nice time on drag radial.... congrat
what is your car power to weight ratio now?
what was your best time with street radial?
BTW The diff is not the only weakness in our drive train. I have a 4.44 gear set in a oem diff. I broke my axle on 3rd launch at last drag.
Old Mar 7, 2005 | 07:08 PM
  #28
blues2k3's Avatar
Default Re: (honda9krpm)
sorry I dont have no new numbers since we are still putting the built block together. I never ran on street radials with the old setup. The car made between 380 to 400 at the wheels previously. I will keep everyone posted on the outcome
Old Mar 8, 2005 | 10:54 PM
  #29
ISSUES-EG's Avatar
Default Re: caged s2000 (Spartan_Vtec_7)
Old Mar 9, 2005 | 05:40 PM
  #30
MugenJibz's Avatar
Default Re: caged s2000 (issues_ek)
very nice
Old Mar 10, 2005 | 06:44 PM
  #31
papa5murf's Avatar
are you building this strictly for drag racing?? or are you also driving this on the streets?
Old Mar 10, 2005 | 07:36 PM
  #32
Nishant's Avatar
Default Re: caged s2000 (03s2kblue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 03s2kblue &raquo;</TD></TR><TR><TD CLASS="quote">are you building this strictly for drag racing?? or are you also driving this on the streets?</TD></TR></TABLE>
earlier he said drag only
Old Mar 11, 2005 | 05:07 AM
  #33
blues2k3's Avatar
Default Re: caged s2000 (Nishant)
the car will be on the streets too, thats why I choose not to do too much cutting of the dash and other areas...
Old Mar 11, 2005 | 08:31 AM
  #34
CHEETAH's Avatar
Default Re: caged s2000 (blues2k3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blues2k3 &raquo;</TD></TR><TR><TD CLASS="quote"> for single digit pass. Hopefully it work out.
good luck arnold , I'm sure that thing will fly ... have you weighed the car yet ?
btw, I have 160 lb injectors if you need LOL ...
Any good leads on a hardtop ?
Greg
Old Mar 11, 2005 | 08:42 AM
  #35
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blues2k3 &raquo;</TD></TR><TR><TD CLASS="quote">the car will be on the streets too, thats why I choose not to do too much cutting of the dash and other areas...</TD></TR></TABLE>
That doesnt make sense. Not putting the tubes through the dash and such puts the bars closer to your (un-helmeted) head on the street, which is exactly what you dont want.
The forward tubes going from the main hoop toward the a-pill also look awfully low to me as well.
If you're going to trash a $20k car with a cage, you might as well do it right the first time, IMHO.
Old Mar 11, 2005 | 09:00 AM
  #36
Nishant's Avatar
that cage is unsafe for driving on the street
Old Mar 11, 2005 | 10:04 AM
  #37
Scot's Avatar
why 3.9's? where did you even get 3.9's? won't that add some stress to the launch since 1st gear will now be good for about 50mph?
Maybe you are using shorter tires? Did you guys figure out the gearing to maximize 4th gear at the end of the qtr? (like you will trap at 125mph which will be the top of 4th with the longer gearing)?
some guy in Florida was going to put a solid rear axle in a drag S2000, but gave up and sold all the parts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blues2k3 &raquo;</TD></TR><TR><TD CLASS="quote">The new diff will run 3.90 gears is a one off capable of holding the power...a slightly modified verison of those seat are being used so the cage was built around the proper dimenson. </TD></TR></TABLE>
Old Mar 11, 2005 | 10:19 AM
  #38
blues2k3's Avatar
Hey Greg,
check out these links on the hardtop:
http://www.s2ki.com/forums/ind...rdtop
I have to get another number for you to. I'll PM you with that info. As for the other comments from others regarding the cage, thank you for your concerns I will share them with the builder...
Old Mar 11, 2005 | 10:21 AM
  #39
blues2k3's Avatar
Scot,
based upon the previous runs and considering the new setup, the differential builder ran some numbers and decided 3.90s were the way to go. Again, this will be trial and error until we get the right setup. Thanks
Old Mar 12, 2005 | 05:03 AM
  #40
jakeiscool's Avatar
Banned
that needs to be painted but looks hot as hell.
Old Mar 13, 2005 | 05:47 AM
  #41
XtremeMotorWerks's Avatar
I don't think that cage is going to legal for a single digit pass. The tubing placement is extremely critical and to be honest the a pillar tubes are done terribly even if i were to not go throught the dash i would have bent the tubing to follow the original chassis better. That is the whole idea to keep the outer shell from moving in at all in the event of a crash. I guess it really depends on what equipment was used to manufacture the cage as well. We use a computer controlled bender that follows our cad program for each individual tube. Our roll cages are design on cad then go through some stress testing programs to come up with the best possible placement and tubing od and wall thickness. Anyways I wish you the best of luck with the car and you new set-up!
Old Mar 14, 2005 | 05:04 PM
  #42
vtecCivicSI's Avatar
Damn!
Old Mar 15, 2005 | 07:15 AM
  #43
TurboKneeGrow's Avatar
Where did you get it done. The welds look really clean. on a job well done.
Old Mar 15, 2005 | 07:21 AM
  #44
blues2k3's Avatar
Default Re: caged s2000 (TurboKneeGrow)
thanks...it was done at chassis evolution in NY
Robbie67
Honda S2000
17
Dec 3, 2009 05:33 PM
Civicboy
Honda S2000
11
Aug 3, 2004 08:56 AM
Razor
Jul 8, 2004 10:52 AM
LSHatch
Mar 12, 2004 12:22 PM
