Honda S2000 Honda S2000
Broken axle - is this common?
Old Jun 10, 2010 | 09:22 AM
Honda Bull's Avatar
Default Broken axle - is this common?
Helped a friend diagnose why his AP1 wouldn't move. Basically, the inner hub to the axle shaft is broken somehow.
When letting the clutch out in gear, the driveshaft spun, the axle hub bolted to the diff spun, but the axle shaft itself didn't move. I haven't pulled it entirely apart yet, other than to inspect the bearings and everything looked fine. I thought maybe it had just popped out since the boot looked funny and stretched, and everything inside looked fine; but once everything was back together, the drivetrain reacted the same way.
Looking at an online parts diagram, what seems to have happened is the part that holds the bearings sit on must be splined to accept splines on the shaft. These parts press together, but it seems the splines must have rounded somehow. Is this a common occurrence? Just seemed odd to me that that had happened.
TIA for any input.
Old Jun 15, 2010 | 10:38 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: Broken axle - is this common?
Not common at all, that I know of! Just replace both axles and call it a day. I have a set if ya need 'em.
fatboy1185
Suspension & Brakes
11
Mar 11, 2010 01:32 PM
FormulaIntegra
19
Jul 4, 2009 09:28 AM
sirhavok
Jun 17, 2007 02:12 PM
Passaudi1.8t
Jan 15, 2004 10:45 PM
Pearce
Oct 16, 2002 10:44 AM
