Honda S2000 Honda S2000
ap2 conversion help!
Old Oct 9, 2006 | 04:38 PM
SwpR's Avatar
Default ap2 conversion help!
Ok guys, I need 2 know how much of a hassle it is doing the ap1 to ap2 conversion. From what I know the bumpers in the front n back including the headlights are just simple installations with no extra pieces or anything...well maybe the black plasrtic that goes on the bottom of the front?
But the back I know involves cutting and rewiring or something...can someone give me a fulkl list of what I neesd for the back? N plz don't send me a link, I just need 2 know what the back involves and if its a hassle bc te shop will bithc if it isn't a pkug n play type install. Plz help asap its for tom morning!
Old Oct 9, 2006 | 04:44 PM
Nishant's Avatar
Default Re: ap2 conversion help! (SwpR)
It is not plug and play. Also, you need to do some work on the front with the headlights. The rear actually requires some cutting for the tail lights to fit.
Old Oct 9, 2006 | 05:24 PM
Nhan's Avatar
Headlights are pretty much plug and play. Tailights is a whole different story. You have to cut out metal to fit the headlilght and you have to modify the wiring.
Old Oct 9, 2006 | 05:25 PM
SwpR's Avatar
Default Re: (Nhan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nhan &raquo;</TD></TR><TR><TD CLASS="quote">Headlights are pretty much plug and play. Tailights is a whole different story. You have to cut out metal to fit the headlilght and you have to modify the wiring.</TD></TR></TABLE>
is it a do it urself thing? or a body shop? do you know how long it takes to do so and if its a hassle or just easy but requires some work? I need to tell them before they order it or else my *** is grass loll thanks a lot btw.
Old Oct 9, 2006 | 05:30 PM
ednyboo's Avatar
Default Re: (Nhan)
tail need to shave some body off. or drill some holes..
and the plugs won't fit,it WILL fit, but u can think it as like trying to fit supernintendo games to N64..
so cheap way to do is u r gonna have to shave off the plastic piece (red LED part)
on the Tailight ,,,,,, and as long as the LED plug fits, lights will work.
and the signal light wont fit into the ap2 taillight
u are going to have to get smaller bulb.
and just let u in my OPINION know ap2 tails are crappier quality compared to ap1.
might have water leak pretty easy and give u pain in the *** and u wont even get it warranteed
igottagsr
Apr 15, 2007 08:07 AM
EG2aGSR
Aug 28, 2006 06:41 PM
fabworxs
Jul 19, 2005 10:10 AM
sk8phaze
Aug 7, 2002 10:59 AM
projectcrx
May 26, 2002 06:25 PM
