Honda S2000 Honda S2000
adjustable camber
Old Jan 11, 2005 | 01:13 AM
arbys2k's Avatar
Default adjustable camber
I'm not sure, but do S2000's have adjustable camber stock?
Also, this is off-topic but what are those plastic things underneath the front bumper in front of the wheels for? Just curious what job they serve.
Thanks!
Old Jan 11, 2005 | 01:37 AM
Ferrell's Avatar
Default Re: adjustable camber (arbys2k)
1) IIRC, there was a honda-tuning a few months back that had an article on the adjustable camber from the factory.
2) Those "plastic things" redirect air away from the tires to improve stability at high speeds.
Old Jan 11, 2005 | 05:30 AM
Tinker219's Avatar
Default Re: adjustable camber (Ferrell)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ferrell &raquo;</TD></TR><TR><TD CLASS="quote">
2) Those "plastic things" redirect air away from the tires to improve stability at high speeds.</TD></TR></TABLE>
I had to rebuild the front end of my car and Honda gave me the same clips that are used to fasten the rear bumper(when you open the trunk, there is 3 I believe).
Well, when backing out in a few inches of snow, both of my strakes fell off. Did Honda give me the wrong clips?
Old Jan 11, 2005 | 06:02 AM
Mr. Bagel's Avatar
Default Re: adjustable camber (Tinker219)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tinker219 &raquo;</TD></TR><TR><TD CLASS="quote">Well, when backing out in a few inches of snow, both of my strakes fell off. Did Honda give me the wrong clips?</TD></TR></TABLE>Unfortunately, it happens. They are the right clips. But when bumped, they don't stay on. A friend of mine has replaced his a few times.
Old Jan 11, 2005 | 07:33 AM
Nishant's Avatar
i thought you had to drill holes for the side strakes?
Old Jan 11, 2005 | 08:12 AM
Tinker219's Avatar
Default Re: adjustable camber (Nishant)
Ya I stopped at Honda today, they say to nut/bolt them for safety. Just gonna be a PITA to get in there. If anything, beefy self tappers will do the trick.
Old Jan 11, 2005 | 08:28 AM
Ferrell's Avatar
Tinker... are you talking about #6 in the illustration, which are also called strakes....
or are you referring to the optional side strakes that go on the rear QP?
Old Jan 11, 2005 | 08:54 AM
Tinker219's Avatar
#6 in that illustration. Ive ordered basically EVERYTHING in there, so ya, I know that illustration very well.
Old Jan 11, 2005 | 09:22 AM
papa5murf's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arbys2k &raquo;</TD></TR><TR><TD CLASS="quote">I'm not sure, but do S2000's have adjustable camber stock?
Thanks! </TD></TR></TABLE>
yes you can adjust the camber and toe of the stock s2k.... but it is limited...
as for the plastic things.. it's been covered.... helps get redirect air away from tires to make the car more stable at high speeds...
Old Jan 11, 2005 | 12:53 PM
terd ferguson's Avatar
Default Re: adjustable camber (03s2kblue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 03s2kblue &raquo;</TD></TR><TR><TD CLASS="quote">
as for the plastic things.. it's been covered.... helps get redirect air away from tires to make the car more stable at high speeds... </TD></TR></TABLE>
I'm certain you can do the more aggressive European alignment which I believe is -2.5 camber. That's quite a bit of adjustment.
Old Jan 11, 2005 | 01:12 PM
papa5murf's Avatar
Default Re: adjustable camber (terd ferguson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by terd ferguson &raquo;</TD></TR><TR><TD CLASS="quote">
I'm certain you can do the more aggressive European alignment which I believe is -2.5 camber. That's quite a bit of adjustment.</TD></TR></TABLE>
yes you can.. i have my car set up to that now... mainly cause i'm dropped close to 2 inches... so i somewhat have no choice hahahaha... but like it said. the adjustability is limited to a certain point...
Old Jan 11, 2005 | 08:03 PM
Nishant's Avatar
i have the stock alignment. i know there is an aggressive alignment too for stock cars. anyone know what they are?
Old Jan 11, 2005 | 08:18 PM
revhi's Avatar
Honda (UK) Recommended Optimum Specification
Front
Caster Left 6° 45"
Caster Right 6° 45"
Camber Left -1° 00"
Camber Right -1° 00"
Toe Left 0° 0"
Toe Right 0° 0"
Total Toe 0° 0"
Rear
Camber Left -2° 00"
Camber Right -2° 00"
Toe Left 0° 20"
Toe Right 0° 20"
Total Toe 0° 40"
Old Jan 12, 2005 | 08:46 AM
beandip's Avatar
Default Re: adjustable camber (revhi)
So how much difference between the Stock chamber and the adjusted camber is there?
Is it enough to notice?
Old Jan 12, 2005 | 11:39 AM
revhi's Avatar
Default Re: adjustable camber (beandip)
The car will have more of a neutral feel. Less over steer. It will handle much better. Down side is more rear camber wear.
Old Jan 12, 2005 | 12:41 PM
Nishant's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by revhi &raquo;</TD></TR><TR><TD CLASS="quote">The car will have more of a neutral feel. Less over steer. It will handle much better. Down side is more rear camber wear.</TD></TR></TABLE>
something i can live with
Old Jan 12, 2005 | 12:55 PM
papa5murf's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nishant &raquo;</TD></TR><TR><TD CLASS="quote">
something i can live with </TD></TR></TABLE>
yes you should do it nishant.. it's so much better.. i have mine set around there somewhere... but then again i'm also lowered about 2 inches..
Old Jan 12, 2005 | 04:31 PM
beandip's Avatar
I personally like Oversteer. Understeer scares the **** out of me. I like being able to still control the car even if it gets hairy
Old Jan 12, 2005 | 04:40 PM
papa5murf's Avatar
yes i rather have overstear and spin out then have understear and fly into that wall.. hahaha..
Old Jan 12, 2005 | 05:28 PM
Nishant's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 03s2kblue &raquo;</TD></TR><TR><TD CLASS="quote">yes i rather have overstear and spin out then have understear and fly into that wall.. hahaha..</TD></TR></TABLE>
oversteer can cause you to spin out and hit the other wall
Old Jan 12, 2005 | 05:41 PM
papa5murf's Avatar
oversteer can cause you to spin out and hit the other wall </TD></TR></TABLE>
hahahah true
Old Jan 12, 2005 | 09:31 PM
Nishant's Avatar
but then if you can control the car, that wouldn't be a problem
Touge Monsta
Aug 1, 2008 05:02 PM
93CamaroLT1
Apr 18, 2008 02:15 PM
lilhatch
Suspension & Brakes
Sep 24, 2005 03:36 PM
h3avyarms
24
Oct 26, 2004 12:57 PM
lDanny
Apr 26, 2004 11:46 AM
