Honda S2000 Honda S2000
16's on the s2000
Old Sep 29, 2007 | 05:05 AM
LumpyTheGrumpyCamshaft's Avatar
Default 16's on the s2000
has anyone run a 16" wheel on a s2000 with 40 series walls, i don't know any rims off hand that are 16x7.5 and 16x8, but with a skunk2 spring, that could look tighter and more compact, any thoughts ?
Old Sep 29, 2007 | 06:53 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: 16's on the s2000 (LumpyTheGrumpyCamshaft)
so your asking about 16's with stock sizes but with 40 series????
Old Sep 29, 2007 | 07:40 AM
- BSeRiouS -'s Avatar
Default Re: 16's on the s2000 (S@nt0s)
in a 16, you should run stock ap1 sizes of 245-45-16 and 205-55-16. 40 series tires will look like ***.
Old Sep 29, 2007 | 08:32 AM
Black S2K's Avatar
Default Re: 16's on the s2000 (I BSeRiouS I)
you got the rear stock size wrong its 225/50 16
Old Sep 29, 2007 | 08:54 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: 16's on the s2000 (Black S2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black S2K &raquo;</TD></TR><TR><TD CLASS="quote">you got the rear stock size wrong its 225/50 16 </TD></TR></TABLE>
yes and no....
the S02 is a "225" but has a contact patch of a 245 so if u got a different tire other then teh S03 then you will be losing tire out back which does NOT make for a fun ride....
Modified by S@nt0s at 6:42 PM 9/29/2007
Old Sep 29, 2007 | 01:52 PM
I know that already
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S@nt0s &raquo;</TD></TR><TR><TD CLASS="quote">yes and no....
the S02 is a "225" but has a contact patch of a 245 so if u got a different tire other then teh S02 then you will be losing tire out back which does NOT make for a fun ride.... </TD></TR></TABLE>
My boy Santos knows wassup. He knows where I was coming from
if you get a non S02 tire, you would technically need to run a 245-45 since the 225 S02 is equivalent to a majority of 245's out there. The s02 225 is oversized.
Some other tires you may run that are also "technically" equivalent to 245's, give or take a few are, but are 225's are, Azenis RT615's , Adavn Nevoa AD07's, Bridgestone REO1-R's etc etc.
Old Sep 29, 2007 | 03:14 PM
Nishant's Avatar
yes and no....
the S03 is a "225" but has a contact patch of a 245 so if u got a different tire other then teh S03 then you will be losing tire out back which does NOT make for a fun ride.... </TD></TR></TABLE>
you mean oem S02 tire....if you want to run S03's then you get a 245 rear
Old Sep 29, 2007 | 05:41 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: 16's on the s2000 (Mr. Nishant)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Nishant &raquo;</TD></TR><TR><TD CLASS="quote">
you mean oem S02 tire....if you want to run S03's then you get a 245 rear</TD></TR></TABLE>
ops.... yes i stand corrected.. its the S02
budget
Honda S2000
Jan 3, 2007 08:21 PM
riceburnngreg
Jul 28, 2006 07:52 PM
GRANT!
10
Jul 9, 2004 02:20 PM
AnNiMosSiTY
Jul 4, 2003 02:02 PM
arw321
Feb 21, 2003 08:34 AM
