wtf is wrong with this pos
Old Sep 16, 2002 | 02:52 PM
91cvcsi's Avatar
Default wtf is wrong with this pos
i just recently replaced all 4 studs on right front wheel because 2 snapped while driving and the other 2 broke when i took the wheel off.....now the problem is the right front wheel is making a squeking noise and one of the lugs is vibrating....why is it vibrating and breaking all my studs....what causes this to happen.....tia
Old Sep 16, 2002 | 03:10 PM
96LudeSiVTEC's Avatar
Default Re: wtf is wrong with this pos (91cvcsi)
Are these factory wheels?
Old Sep 16, 2002 | 05:28 PM
91cvcsi's Avatar
Default Re: wtf is wrong with this pos (96LudeSiVTEC)
yes, 96 vtec
Old Sep 16, 2002 | 06:00 PM
4wsB21a's Avatar
New User
why is this in the prelude forum? did you swap in an h22 or something? otherwise ask someone in the civic forum. maybe this is something that happens with that model that they have figured out.
Old Sep 16, 2002 | 06:02 PM
91cvcsi's Avatar
Default Re: wtf is wrong with this pos (4wsB21a)
I have a 96 prelude i'm on my buddies computer, can you give me any insight on the problem
Old Sep 16, 2002 | 06:39 PM
aklucsarits's Avatar
New User
Are you using the stock lugnuts? And are you torqueing them to spec with a torque wrench?
If you answered "yes" to both of these, I would say it's sounding like a bad wheel bearing.
Anrdew
[Modified by aklucsarits, 10:42 PM 9/16/2002]
Old Sep 16, 2002 | 07:28 PM
Default Re: wtf is wrong with this pos (aklucsarits)
On factory wheels I counting on torque specs. If your not using a torque wrench then you are possibly over torqueing the lugs. I'll do some checking tomorrow with one of my boys and see if it is common on your particular car.
Old Sep 17, 2002 | 07:03 AM
91cvcsi's Avatar
I thought it was the berrings i'll check that out thanks for the advice
Old Sep 17, 2002 | 07:29 AM
bgod's Avatar
bearing, possibly a bent axle causing too much vibration.
i'd say the bearing though.
Old Sep 17, 2002 | 01:41 PM
714's Avatar
714
Default Re: wtf is wrong with this pos (bgod)
Are the lug hole on the wheel possibly worn from driving with loose lugnutz?
southcoast integra
Nov 15, 2006 05:08 PM
5thGenCivicKid
Mar 14, 2005 02:44 PM
TruNinja619
Dec 21, 2004 06:04 PM
migs
Dec 30, 2002 08:57 AM
Understeer
Jun 10, 2002 05:59 PM
