is it worth getting a vtec controller?
Old Apr 11, 2005 | 10:57 AM
  #26
lewdude's Avatar
Default Re: is it worth getting a vtec controller? (dreamer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dreamer &raquo;</TD></TR><TR><TD CLASS="quote">
whatever floats yer boat. I drive a POS civic what do I know</TD></TR></TABLE>
Do you even know what ATTS is or are just following all the other drag racing ricers out there?
I think ATTS is great for the twisties.
Old Apr 11, 2005 | 11:07 AM
  #27
prelittlelude's Avatar
Default Re: is it worth getting a vtec controller? (jfingers)
vtec controler is not worht it. rice in my opinion
most don't modify fuel and none modify spark. you need extensive modification past just very basic bolt ons to warrent changing the stock engaugement point and at that you would also want to be modifying ignition
i hate vtec controlers, they engauge the hi cam without the ecu being on the hi cam fuel and spark map so the ecu cannot be making proper compensation for the higher lift and duration when vtec is engauged
if you think your at the point for some type of fuel management, look into http://www.pgmfi.org or hondata or aem ems, depending on your budget
Old Apr 11, 2005 | 11:22 AM
  #28
A Blue Lude's Avatar
Default Re: is it worth getting a vtec controller? (Drag_On)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drag_On &raquo;</TD></TR><TR><TD CLASS="quote">Huh?</TD></TR></TABLE>
Hondata = OBD1 ECU of some kind or another. There are not a whole lot of OBD1 ECUs that can also handle ATTS.
Old Apr 11, 2005 | 11:28 AM
  #29
bad-monkey's Avatar
Default Re: is it worth getting a vtec controller? (Featherfire)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Featherfire &raquo;</TD></TR><TR><TD CLASS="quote">Hondata = OBD1 ECU of some kind or another. There are not a whole lot of OBD1 ECUs that can also handle ATTS.</TD></TR></TABLE>
there are none.
if you wanna keep your ATTS, you pretty much have to go with an E-manage or a VAFC. looking at your level of mods, both are appropriate to your build. someone mentioned earlier that it's not about peak hp and they're right. smoothing out the curves, gaining power/tq in the midrange, it can be done with a VAFC, and it's worthwhile.
also, for the hondata fans, i would love a hondata, however, it's not "just a little more expensive" than a VAFC. p28+s200+conversion harness comes out to about 500 bucks, vs 200 bucks for a VAFC. unless someone has a secret place where they get their hondata systems...
Old Apr 11, 2005 | 06:33 PM
  #30
LINK76's Avatar
Default Re: is it worth getting a vtec controller? (bad-monkey)
How can we SH owner get a hand on the Type S ecu; so we can apply the Hondata system....... and can you elaborate on the capabilities of the E-Manage over the vafc.
Old Apr 11, 2005 | 08:44 PM
  #31
Ministry's Avatar
Default Re: is it worth getting a vtec controller? (lewdude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lewdude &raquo;</TD></TR><TR><TD CLASS="quote">Do you even know what ATTS is or are just following all the other drag racing ricers out there?
I think ATTS is great for the twisties.</TD></TR></TABLE>
exactly. I'm a drag ricer. I have no idea what ATTS is. I thought it was yet another experimental gimmick Honda decided to try on the prelude, much like the 4ws found on some 4th gens. but I guess I was wrong.
with your ATTS, I'm sure your 3000+ lb pig will pwn me in the twisties y0!
Old Apr 11, 2005 | 08:49 PM
  #32
Lude-acris's Avatar
lol this ***** funny. People want different things, if you wanna have a straight up drag car and dont give a **** about cornering and ripping around turns, so be it ATTS isnt for you. If you like to rip around the turns and dont care about the extra weight, then by all means go for the ATTS. Everything is opinion based.
Old Apr 12, 2005 | 10:04 AM
  #33
lewdude's Avatar
Default Re: is it worth getting a vtec controller? (Lude-acris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lude-acris &raquo;</TD></TR><TR><TD CLASS="quote">lol this ***** funny. People want different things, if you wanna have a straight up drag car and don't give a **** about cornering and ripping around turns, so be it ATTS isnt for you. If you like to rip around the turns and don't care about the extra weight, then by all means go for the ATTS. Everything is opinion based.</TD></TR></TABLE>
Sure people have opinions, but if you don't know **** about what your slamming, then they should keep their mouth shut, that's all.
Old Apr 12, 2005 | 10:14 AM
  #34
Ministry's Avatar
lol I know what ATTS is you silly noobs. I was just suggesting that it doesn't exactly make me giggle. If you can get excited about it, good for you!
and yes, I have driven an SH. I drove one before I bought my 5th gen base model. Both of them handle like bloated pigs in my opinion, with the SH showing a little less understeer.
Old Apr 12, 2005 | 11:17 AM
  #35
SiRLudeVtec's Avatar
yes- if you're not doing too much i guess
Old Apr 12, 2005 | 12:04 PM
  #36
lewdude's Avatar
Default Re: is it worth getting a vtec controller? (SiRLudeVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRLudeVtec &raquo;</TD></TR><TR><TD CLASS="quote">yes- if you're not doing too much i guess</TD></TR></TABLE>
Yes what? I dont get it....what you talking about?
Old Apr 12, 2005 | 01:24 PM
  #37
Dougs96SI's Avatar
Yes what? I dont get it....what you talking about? </TD></TR></TABLE>
I believe he is replying to the original topic.
Old Apr 12, 2005 | 03:39 PM
  #38
lewdude's Avatar
Default Re: is it worth getting a vtec controller? (Dougs96SI)
lol...oops, all I saw was that he replied to me, but the reply was relly not for me I guess. poo
Old Apr 12, 2005 | 04:52 PM
  #39
edulerp97's Avatar
Default Re: is it worth getting a vtec controller? (tdo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tdo &raquo;</TD></TR><TR><TD CLASS="quote">Hondata S200 </TD></TR></TABLE>
My words Exactly.......
Old Apr 12, 2005 | 05:52 PM
  #40
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dreamer &raquo;</TD></TR><TR><TD CLASS="quote">lol I know what ATTS is you silly noobs. I was just suggesting that it doesn't exactly make me giggle. If you can get excited about it, good for you!
and yes, I have driven an SH. I drove one before I bought my 5th gen base model. Both of them handle like bloated pigs in my opinion, with the SH showing a little less understeer.</TD></TR></TABLE>
the atts still provides some traction in a straight line.....you will be the gayass hopping all the way down the 1/4 on your poor right tire.....
Old Apr 12, 2005 | 07:30 PM
  #41
LINK76's Avatar
Default Re: is it worth getting a vtec controller? (mgags7)
so the ATTS is like a traction / LSD ?.....I thought it just help on cornering becuase it only sensing the side to side body roll and transfer torque to the out side wheels so understeering is eliminated.
Old Apr 12, 2005 | 07:57 PM
  #42
Ministry's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">the atts still provides some traction in a straight line.....you will be the gayass hopping all the way down the 1/4 on your poor right tire.....</TD></TR></TABLE>
wrong. ATTS does nothing in a straight line.
Old Apr 12, 2005 | 09:17 PM
  #43
bad-monkey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dreamer &raquo;</TD></TR><TR><TD CLASS="quote">wrong. ATTS does nothing in a straight line. </TD></TR></TABLE>
the ATTS hater is right.
Old Apr 13, 2005 | 04:37 AM
  #44
Ministry's Avatar
you guys, I'm not trying to hate. this all started with a statement of opinion, although I guess it was uncalled for and kinda off topic. but who cares what I think?
and by the way, I am the gayass hopping down the track on one wheel. actually, my wheels don't hop, they just spin. open diff = one wheel wonder
Old Apr 13, 2005 | 07:47 AM
  #45
lewdude's Avatar
Time to switch the tranny for you then. LSD anyone?
Old Apr 13, 2005 | 09:33 AM
  #46
98vtec's Avatar
moderator emeritus
Default Re: is it worth getting a vtec controller? (LINK76)
its good for someone who isnt going to be building a motor, if you are sticking with bolt ons, a vafc is perfect for you.
Old Apr 13, 2005 | 10:17 AM
  #47
Elkins911's Avatar
Default Re: is it worth getting a vtec controller? (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">its good for someone who isnt going to be building a motor, if you are sticking with bolt ons, a vafc is perfect for you.</TD></TR></TABLE>
almost EVERYONE is getting off topic. 98vtec is right, if you have basic bolt ons... VAFC is all you need. you wont be getting the best gains from it, but your will be getting something... it WILL shave time off of 1/4 miles and WILL improve how your engine runs. bottom line, VAFC is perfect for you.
Old Apr 13, 2005 | 10:38 AM
  #48
why hasn't this thread died?
only a vtec controler = The GhEy
some tuneability past just vtec engaugement point = meh maybe if it were free
Old Apr 13, 2005 | 11:45 AM
  #49
98vtec's Avatar
moderator emeritus
Default Re: is it worth getting a vtec controller? (prelittlelude)
whats the point of putting a 400 dollar system plus 200-300 dollars in tuning into a stock motor....hmmm...yeah, no point.
jdmh22luda
Jul 26, 2005 01:22 PM
jfingers
Jul 18, 2004 09:03 PM
slosol
Jan 11, 2004 01:39 PM
typeR 507
Aug 29, 2003 03:24 PM
Bbasso
Feb 13, 2002 03:06 PM
