Is this worth it?
Old Nov 12, 2005 | 07:14 AM
AnthonyG2003
Guest
Posts: n/a
Default Is this worth it?
I was wondering if it would be worth buyin these? http://cgi.ebay.com/ebaymotors...wItem
Old Nov 12, 2005 | 07:26 AM
GaRn's Avatar
Default Re: Is this worth it? (AnthonyG2003)
Yea you will pick up a few hp, and if you aren't looking to spend an arm and a leg for a header, then go for it, just don't bolt up the B pipe bracket to the back of the block, there have been several instances of them breaking off(mine included).. you don't need to bolt that up anyways.
Old Nov 12, 2005 | 07:28 AM
InvaderTrax's Avatar
Looks exactly like mine. Better deal then I got too. I'd jump on those. Mine don't leak, and flow great. Not to mention they were about 10lbs lighter then stock. Only thing you'll want to do is buy a header gasket, then hold it up against the flange and see how well it matches up. I had to grind mine out just a little here and there to make it perfect
Old Nov 12, 2005 | 08:45 AM
Lewdin' Incognito's Avatar
Default Re: (InvaderTrax)
The Si (2.3) header is lot more constrictive than the H22 header; your 2.3 will love you for just about anything other than the stock one.
Modified by Lewdin' Incognito at 1:36 PM 11/12/2005
Old Nov 12, 2005 | 10:39 AM
RemerLex11's Avatar
go for it but remember you get what you pay for
michaelprice83
Welding / Fabrication
Oct 12, 2010 05:26 AM
TheAccordGuy
Jun 27, 2006 08:24 AM
SpeedFreak77
Mar 26, 2006 10:08 PM
MKIIISupra
Sep 8, 2005 03:11 AM
ebelp
Jul 29, 2003 10:21 AM
