Wiring through the firewall
Old Sep 30, 2002 | 04:52 PM
blacklude's Avatar
Default Wiring through the firewall
I'm trying to get a wire into the engine bay from the cabin, and I want to do it through the firewall. Where would the best place be to put the wire through? Thanks.
Old Sep 30, 2002 | 05:02 PM
TimeRacer's Avatar
Default Re: Wiring through the firewall (blacklude)
What gauge wire? All of my wiring that I've routed into the cabin has been via the grommet under the fusebox. I have 3 sets of 16 gauge wire plus a 0 gauge wire for my amps.
Old Oct 1, 2002 | 05:44 AM
Daemione's Avatar
Default Re: Wiring through the firewall (TimeRacer)
Yeah, there's a rubber grommet where the engine wiring harness goes through. You can see it if you take out the fuse box on the passenger side of the engine bay. It's a pain to get to on the other side, but there's plenty of room in that rubber boot for incisions & other wires.
Old Oct 1, 2002 | 06:09 AM
prelude1897's Avatar
I drilled a hole by my clutch pedal, and I had my power wire for my amp run through there. Just be careful not to hit anything if you decide to drill a hole
Old Oct 1, 2002 | 02:13 PM
armharm's Avatar
Default Re: Wiring through the firewall (prelude1897)
i ran an 8 gauge power cable from the top passenger side of the hood thru the fender down thru my door into my cabin for my amp.... it sounds ghetto but hey... i didnt have to drill anything...
Old Oct 2, 2002 | 02:51 PM
blacklude's Avatar
Thanks for all the help guys, im going to go look for the grommet behind my fuse box.
Old Oct 2, 2002 | 04:20 PM
rybred's Avatar
Definetly the best location to go through the firewall!
Old Oct 2, 2002 | 05:07 PM
ViZ's Avatar
ViZ
Default Re: Wiring through the firewall (Rybrid)
i recomend getting some solid not stranded wire the stiff stuff maybe 10-12 gauge and using that to push through then tape your wire to it and pull it through.. like a fish tape if anyone knows what that is.. saves alot of time and effort
Old May 7, 2006 | 05:40 PM
RusBear's Avatar
Default Re: Wiring through the firewall (ViZ)
I just did that, two tips:
- Under the fuse box, there are two grommets. I had luck with the one closer to the driver's side.
- To get to the wire on the other side, I took off the glove box, and then could see the wire through the small opening in the center.
Tippyman
Audio / Security / Video
23
Nov 28, 2008 03:10 PM
leftychang
Welding / Fabrication
23
May 6, 2008 04:38 AM
Pikachu
Apr 30, 2005 09:38 PM
2fast4udude
Mar 8, 2005 03:18 PM
92BlackSi
Nov 30, 2003 10:27 AM
