Wiring an O2 Sensor; ECU or sensor
Old Dec 30, 2001 | 02:00 PM
Defiant1999's Avatar
Default Wiring an O2 Sensor; ECU or sensor
I have recently got a AutoMeter O2 sensor and I ahve heard from lots of people NOT to wire it through the O2 sensor because it has mad there cars run rich, and teh O2 sensor go out, please help
Old Dec 30, 2001 | 08:32 PM
DirtyLude's Avatar
Default Re: Wiring an O2 Sensor; ECU or sensor (#1lude)
It shouldn't make a difference. Two different point on the same wire.
Just wire it at the ECU, it's easier. Make sure and use the ECU power and ground as well, or there's a chance you'll get noise that screws around with the readings.
Old Dec 30, 2001 | 09:40 PM
Greyout's Avatar
Default Re: Wiring an O2 Sensor; ECU or sensor (DirtyLude)
really? I get my power from the accessory wire that goes to the radio, and ground it behind the dash somewhere... I have like 5 LED's light up at once at WOT but I'm told thats normal for a honda?
Old Dec 31, 2001 | 05:54 AM
DirtyLude's Avatar
Default Re: Wiring an O2 Sensor; ECU or sensor (JDM LUDE)
The noise isn't that bad. You're fine using regular power and ground. On a couple cars I've seen that are using standard power and ground, when the windows are open/closed or the power door lock activate you get lights lighting up.
video_voide
Jan 7, 2017 11:12 AM
portfl0w
Apr 17, 2007 09:12 PM
RobbieG35
Jun 21, 2006 07:29 AM
94turbodelsol
Aug 17, 2005 08:16 AM
nkt001
11
Oct 21, 2004 03:35 PM
