Wire Harness Help
Old Apr 18, 2017 | 09:05 PM
snowblind7x's Avatar
Icon5 Wire Harness Help
I have a 93 Si VTEC. I need to figure out what the wire harness i need is called so I can perhaps find one. I'm looking for the wire harness that the main engine harness plugs in to at the passenger side shock tower. To be technical, its the harness that plugs into connectors c135 and c136 that i'm in search of. So its the harness that goes through the firewall on the passenger side and connects to the main engine harness. What harness is this? What does it connect to in the cabin? Just straight to the ECU?
Thanks!
Old Apr 27, 2017 | 01:57 PM
Default Re: Wire Harness Help
BUMP
Old Apr 27, 2017 | 09:01 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
It would be called the cabin harness. Honda part number is 32100-SS0-A00
Old May 3, 2017 | 09:02 AM
Do you happen to know what/where it connects inside the cabin?
Old May 3, 2017 | 06:48 PM
JRCivic1's Avatar
10 Year Member
Community Builder
EVERYWHERE !!! Fuse box, dash harness, engine harness, through the firewall to the drivers side and passenger side shock towers, to the center tunnel, to the rear sub harness, to both door jams, and the left kick panel to meet the sunroof/dome light sub harness... shall I continue ?!? LOL
Old May 4, 2017 | 06:40 AM
ISUBIEXI's Avatar
Yea the cabin harness is a nightmare. I wanted to separate the cabin harness from the ECU but its a huge project, it was easier just to pull the cabin harness connections from the engine bay thru the firewall.
Do you have an issue your trying to resolve?
slow_sihatch
Apr 8, 2013 07:40 PM
MrToasty
Jan 3, 2007 05:04 AM
ch00dlz
Jul 24, 2006 09:18 PM
