will sh ecu work on base model??
Please help me anything will do....car is flooded everything works still engine runs AC works but no rev over 3000 rpm I got 7 codes which leads to faulty ecu I can't find an p5m-l04 only p5p-l04...p5p is an sh ecu p5m is base model only difference is base model has no ATTS so why wouldn't p5p work on base or will it please help me
Last edited by elputipuerco; Apr 15, 2016 at 03:46 PM. Reason: misspelled model on title
First off do you have an auto or manual transmission on your prelude and secondly any ecu you put in there will have to be taken to the dealership to have the immobilizer re flashed to your key so that your car will start. At this point in time if you do not have to pass smog or anything of that nature just buy a chipped obd1 ecu with h22 basemap on it as well as an obd2a-obd1 jumper harness and call it a day.
It's 5 speed cause sh only came 5 speed my base model is 5 speed too...I just can't find my an ecu for a base model only sh so all I wanna know is if it's compatible sh to base
Here you go right here on eBay: Honda H22 ECU ECM MT 37820 P5M 003 076 100501 MJM | eBay
That's a jdm ecu mine is p5m-l04 that's a usdm base model ecu an sh usdm is p5p-l04 I wanna know If the sh ecu will be compatible with my base model prelude
Yes I know what those ecu codes are and which cars that they go to. I'm saying to you the jdm edu is better due to the fact there is no immobilizer to bypass so you don't have to waste your time or money at the dealership having them reflash your key for the new ecu. I really dont know if the sh ecu will work for the base prelude.
It allready comes with a greedy tunning computer that does it n it has msd coil n computer....reason I want regular ecu is cause it's a daily driver it's got AC and I wanna keep it street not drag I feel doing all the tuning is to much for a car that's daily driven....I am in San Antonio on Tuesday a hail storm from he'll hit n damaged my roof n trunk I found a trunk for forty dollars allready (he'll of a deal) on the way home water got into my passenger side n wet everything were my ecu n msd computer is so i took the msd computer off n connected straight to the msd coil n still no rev beyond 3000 my tunning computer is not wet cause its way to high for water to get in it but my ecu had water corrosion on the sides so i know is bad and i connected the computer to check my codes and everything it pointed was ecm after some research the ecm is inside the ecu so i need a nsw ecu n I found the only ecu that's not automatic or jdm but it's of an usdm sh model I allready have a p13 jdm ecu but I used it before n like I told you it ran too rich n hella smoke came out the exhaust n it's not recommended to use jdm ecu on usdm motor.....I really need to just know the compatability between this two I need my car asap n I don't wanna drive 3 hours to get an ecu that won't work with my car know I mean
From what I remember, when guys have swapped out the SH tranny and ATTS for a base tranny, their cars still ran properly on the SH ecu, so it "should" work right for you as well. The ATTS has it's own ecu that would have issues, but a base model car will not have that, the wiring, the sensors etc.
I appreciate everything guys and thanks am a just go with the sh ecu.....now I have my prelude RED KEY, how and where can I find a link to reprogram my key at home with my RED KEY that comes with the car when you purchase it from the dealer
JinMTVT
Nov 15, 2001 07:03 PM
