wheel size
Old Dec 3, 2008 | 08:35 AM
94jdmlude's Avatar
Default wheel size
i'm runnin 17'' wheels on my 94 lude. what was the stock wheel size and what size does everybody choose to run?
Old Dec 3, 2008 | 08:36 AM
98vtec's Avatar
moderator emeritus
personal preference:
15" or 16"
Old Dec 3, 2008 | 08:47 AM
94jdmlude's Avatar
whats the pros of 15" or 16" wheels? what you runnin 98vtec?
Old Dec 3, 2008 | 08:53 AM
98vtec's Avatar
moderator emeritus
over a 17"+ wheel:
weight
adjusts to a shorter gear ratio = greater acceleration/decreased top speed
better choices for rubber
i run a 16x7.5 wheel for the street and a 15x7 wheel for drag racing.
Old Dec 3, 2008 | 08:56 AM
A Blue Lude's Avatar
IDK, I think there is way more selection of good tires in the 17" range.
Old Dec 3, 2008 | 11:45 AM
ethereal2pt2's Avatar
Originally Posted by 98vtec
over a 17"+ wheel:
weight
that depends on the tire size you choose to run. i know you know this but it's all about overall diameter, not only the rim. you could run a 15'' rim and still have the same ratio as a 16'', 17'', or 18''. for example, for a 5th gen, i believe the stock size is 205/50/16. the overall diameter of this setup is 24.1''. now change that into a 15'' rim and you need to up the size of the tire from 205/50 to 205/55 and you get a overall diameter of 23.9" this means your speedo reads 60 you're really going 59.5mph. not a big difference really. it's simple, more rim, less tire. but if you chose the same aspect ratio for for 15'', the overall diameter will bee 23.1" which would change the ratio.
edit: weight also plays a big role but that's a different story, unsprung weight ftl.
CDeeznuts
Oct 27, 2008 01:06 PM
DigitalPunk
May 22, 2006 09:23 PM
bleek
Feb 16, 2005 10:50 PM
BlackEG4
Jan 9, 2005 02:41 AM
LSeeper
Dec 18, 2003 05:27 PM
