Weird Electrical Problem With Tail Lights
Old Oct 9, 2005 | 11:41 PM
1989Prelude's Avatar
Default Weird Electrical Problem With Tail Lights
Maybe someone can help...
When I start my car, everything seems normal. But, once I hit the brake pedal, turn on the hazard lights or use my turn signal, the "brake light" lights up on the car diagram in the dashboard. Then, the left and right turn signal indicators come on (faintly) whenever I hit the breaks or turn on the hazard lights, or use the turn signals. The brake light in the rear window lights up, bit the yellow tail lights come on and the red tail lights go off when I hit the brakes.
Thank you!
Old Oct 10, 2005 | 06:39 AM
M@'s Avatar
M@
Default Re: Weird Electrical Problem With Tail Lights (1989Prelude)
Maybe you have a burnt out bulb.
Old Oct 10, 2005 | 09:26 PM
Default Re: Weird Electrical Problem With Tail Lights (M@)
"Maybe you have a burnt out bulb"
I tried that, but no burnt out bulbs. Thank you.
Old Oct 11, 2005 | 05:01 AM
M@'s Avatar
M@
did you replace it with the correct bulb. I don't know about this being true for your car, but I've heard that they work on resistance. If you have a different resistance bulb then it can fool the car into thinking a bulb is burnt out.
Old Oct 12, 2005 | 02:24 PM
FlyingDaggers's Avatar
Get a wiring diagram for the tail lights and follow that to the ground. All of those u mention shared a common ground so one or more of those could have short to ground. First things first, check for a common--what do they all share in common...and then check for that--usually its the ground that everything always share in common. Check that out 1st.
Daggers
Old Oct 12, 2005 | 04:48 PM
Default Re: Weird Electrical Problem With Tail Lights (FlyingDaggers)
Thanks! I will try it...
Old Oct 12, 2005 | 05:04 PM
Can anyone help me find a tail light/hazard/turn signal wiring diagram? I searched the forums and tried Google. Thanks again!
Old Oct 12, 2005 | 05:29 PM
plikit's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M@ &raquo;</TD></TR><TR><TD CLASS="quote">did you replace it with the correct bulb. I don't know about this being true for your car, but I've heard that they work on resistance. If you have a different resistance bulb then it can fool the car into thinking a bulb is burnt out.</TD></TR></TABLE>
you are correct sir. i converted my corner lights to turn signals because the body kit i chose didnt have spots for stock turn signals. i got amber bulbs and rewired the turn signals to the new plugs but they still flash fast as if theyre burnt out. ive yet to figure out a way to fix it.
mikeSMASHES
Feb 10, 2010 12:41 PM
xionl1350
Honda S2000
12
Jul 17, 2008 05:16 PM
rewerbcrx
Sep 4, 2006 03:17 PM
sircrxracer
Jul 31, 2004 10:20 AM
DV98CVC
Aug 22, 2002 06:23 PM
