Web Cams??
Old Mar 20, 2003 | 04:15 PM
IS1's Avatar
IS1
Default Web Cams??
Anyone here use Web's cams for the H22? If so what do you think?
Old Mar 20, 2003 | 05:04 PM
prelude22085's Avatar
Default Re: Web Cams?? (Import Solutions)
I have an H23 Vtec.......The H22 Head. I have Web cam re-grinds on mine. I think that they rock. Great power band! I highly recommend them!
[Modified by prelude22085, 9:04 PM 3/20/2003]
Old Mar 20, 2003 | 05:05 PM
One Slow Lude's Avatar
Default Re: Web Cams?? (prelude22085)
What kind of $ figure on those boys???
Old Mar 20, 2003 | 05:15 PM
MugenPoweredLude's Avatar
Default Re: Web Cams?? (POSlude97)
I never heard of those...I want some SKUNK2 StageII cams
Old Mar 20, 2003 | 06:49 PM
Boosthead's Avatar
I have web's and think they're great. Ask Bgod. He's used them.
Old Mar 20, 2003 | 09:01 PM
NXLude's Avatar
I dont know of anyone who has used them, but they are cheap. They cant be that bad cause they make them for like every app. They will make any custom grind for $655. Thats cheaper than anyone (at least skunk). Try em and find out.....
Old Mar 21, 2003 | 05:26 AM
Default Re: Web Cams?? (NXLude)
The real question is do they make nearly enough power like the Skunk2 cams do?
If so, then thats a great price
Old Mar 21, 2003 | 07:35 AM
Default Re: Web Cams?? (MugenPoweredLude)
These re-grinds have a much more agressive grind then skunk 2 does.
Old Mar 21, 2003 | 01:28 PM
prelude beast's Avatar
do web cams turbo cams for a h23 non vtec and do any body know how good they are and how much horse power gain you will get.
Old Mar 21, 2003 | 01:45 PM
4bidden's Avatar
Default Re: Web Cams?? (prelude beast)
Why not just have WebCam make you a custom grind to Skunk2 specs? It'd still be cheaper.
Old Mar 21, 2003 | 01:49 PM
Default Re: Web Cams?? (4bidden)
you got some good ideas, if they are reliable
anyone know how reliable they are?
Old Mar 21, 2003 | 02:53 PM
NXLude's Avatar
Thats the point i wanted to make, just have them grind you whatever for 655$$$ They make ferrari and lambo cams......cams for lawwnmowers (really) also. I would try them......but thats me, they seem ok...
Old Mar 21, 2003 | 03:48 PM
4bidden's Avatar
I have heard nothing but good about them. I have heard some people call their springs/retainers some of the best out there.
Old Mar 21, 2003 | 06:58 PM
se93's Avatar
I have a brand new set of Billet Webcams for an all-motor H22A application. I also have a set of two month old used Webcam valvesprings and titanium retainers. If you are seriously interested, email me .
Old Mar 22, 2003 | 08:07 AM
IS1's Avatar
IS1
Default Re: Web Cams?? (se93)
Thanks for all the feedback. The reason i asked is i have a set of Web Cams in a customers car ('92 prelude H22) and they rip. However this is the second set, i had to send the first set back because it had really abnormal cam wear. Web re-ground them and sent them back at no charge. Now 5000 miles later it's having the same problem. Web said to just keep sending them back and the'll keep re-grinding them. For those of you who think they were installed wrong Web inspected them and said they were properly installed and broke in, but for some strange reason they keep "wearing out". These cams are awesome but i was just wondering if this is what i am suppose to expect from re-grinds. I had JG re-grinds and they the same thing. Again THANKS for all the feedback.
Old Mar 22, 2003 | 04:20 PM
Dude thats beat, you have to keep sending them back out. Ouch. has anyone else had this problem, even with other companies?
Old Mar 24, 2003 | 08:50 AM
What grind is on the cams??? Im me or email me (gt22285@aol), let me know. I am interested.
Old Mar 24, 2003 | 12:57 PM
se93's Avatar
I tried emailing you, but got an error message.
Email me at: se93@xsn.net
Old Mar 24, 2003 | 01:02 PM
se93's Avatar
Here are the specs:
Engine: Honda Prelude VTEC (Big lobe only)
Grind # 498-15-89a/498 + 2.5 degrees - 265-267
INTAKE
Valve lash stock
Valve lift .465
Duration 280*
Duration @.050 255*
Lobe center 110*
EXHAUST
valve lash stock
valve lift .426
Duration 282*
Duration@.050 255*
Lobe center 110*
Intake opens 17.5 Before TDC*
Intake closes 57.5 After BDC*
Exhaust opens 55 Before BDC*
Exhaust closes 15 After TDC*
* (in degrees)
You can call Webcam to confirm the specifics on these all-motor billets.
Old Mar 25, 2003 | 02:51 PM
baddboy's Avatar
anyone ever use them on their NA H23
CyborgGT
Nov 13, 2016 04:11 PM
Scott53092
Oct 17, 2010 06:13 PM
BrowNKiD
Feb 23, 2009 06:36 PM
95accordh22a
Jun 28, 2005 06:51 AM
dflipmode
Apr 3, 2002 08:33 AM
