Water Pump Replacement
Old May 9, 2008 | 03:46 AM
circuit plus's Avatar
Default Water Pump Replacement
Hello, I just changed my water pump on a 93 h22a engine. After I put everything up and started the engine it ran fine except that now it has a vibration.
Any solutions or causes for this problem?
Thanx.
Old May 9, 2008 | 03:52 AM
no1knows908's Avatar
Default Re: Water Pump Replacement (circuit plus)
First thing I would check is to make sure your balancer shafts were properly aligned before you put the belt back on. I seemed to have a hard time getting the front one properly aligned but I finally got it perfect.
Old May 9, 2008 | 05:52 AM
Acidcrakker's Avatar
Default Re: Water Pump Replacement (no1knows908)
Did you bleed your coolant afterwards?
Old May 9, 2008 | 02:20 PM
vlang29's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by no1knows908 &raquo;</TD></TR><TR><TD CLASS="quote">First thing I would check is to make sure your balancer shafts were properly aligned before you put the belt back on.</TD></TR></TABLE>
x2
both shafts HAVE to be set correctly or it will vibrate like crazy
Old May 9, 2008 | 06:32 PM
lude98SH's Avatar
Default Re: Water Pump Replacement (Acidcrakker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker &raquo;</TD></TR><TR><TD CLASS="quote">Did you bleed your coolant afterwards?</TD></TR></TABLE>
I dont think that would cause a vibration.
mizzoEG
Jul 21, 2007 06:00 PM
Draggin99Si
Jun 8, 2007 09:28 PM
baonest
Dec 9, 2006 02:08 PM
kb58
15
Jun 14, 2006 05:41 PM
Raskal
Jan 27, 2005 07:01 AM
