Vtec quit workin what the problem?
just as my title stats I have a accord with a jdm swap and my vtec just quit workin while I was driving down the road. and I checked all the wires and coolant and oil level and there all fine so what's the problem?
woah, you have the same problem as me. When Vtec quits working, your in limp mode. the first thing i would check is your ECU. See, my problem is that my car wont let me redline to 7500 and it wont also hit vtec. My tach stops at 6000 and the engine responds to that, and then engine wont go any furrther than 6000. So if you do find out what the problem is why dont you hit me up too. My freind fucked with the gauges to install indiglos and now my car refuses to hit redline or vtec
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Superman137 »</TD></TR><TR><TD CLASS="quote">the only code I been throwing was for a bad o2 sensor and that's been on for a while </TD></TR></TABLE>
did you check to make sure it was the same code? Which o2 code is it, there are a couple.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MUGEN_CF4 »</TD></TR><TR><TD CLASS="quote">Check your oil level, if your oil level is ok come back here and hit the search button.</TD></TR></TABLE>
check oil level too.
I figured out the problem it was the plug beside the vtec solenoid it wasn't plugged in all the way some how it worked itself a loose. Thanks for the help everybody
