vtec pressure switch
Old Aug 29, 2006 | 06:36 PM
-Bionic-'s Avatar
Former Sponsor
Default vtec pressure switch
How common is it for the vtec pressure switch to go bad? I got roughly 50K on it, and it seems to stop working. Any suggestions on how to trouble shoot to see if it's faulty? Tried to search for it, but no luck.
TIA
Old Aug 29, 2006 | 07:25 PM
98vtec's Avatar
moderator emeritus
Default Re: vtec pressure switch (-Bionic-)
download a helms manual and find out what the voltage is supposed to be. Then test the voltage with a mulitmeter.
Old Aug 29, 2006 | 07:40 PM
-Bionic-'s Avatar
Former Sponsor
Default Re: vtec pressure switch (98vtec)
Thanks
How common is it that people change/replace these pressure sensor/switch?
Old Aug 30, 2006 | 06:46 AM
prelittlelude's Avatar
its only a swith, so measuring it with resistance. should be open with no presure and closed when presure applied.
they can get clogged and can go bad, check wiring as well
Old Aug 31, 2006 | 08:15 PM
-Bionic-'s Avatar
Former Sponsor
Default Re: vtec pressure switch (prelittlelude)
Thanks.
I checked wiring, and that seemed to have been a problem. The OBDI - OBDII harness seemed to have poor connection, so I jumped it. But now I'm getting a CEL. Code 22, so I"m thinking that the solenoid is goiing, or the connection from the ECU to the solenoid isn't good..as with the pressure switch, and perhaps the oil pump is going, or gone. I don't have a oil pressure guage to check this at the moment.
Thanks for the comments.
Old Sep 2, 2006 | 04:50 PM
to me sounds like all your problems are in you wiring. good luck
Delphince
Engine Management and Tuning
23
Jun 8, 2018 05:18 AM
UDUBdriver
Sep 4, 2011 07:04 AM
barone
25
Aug 20, 2009 08:32 AM
fw190bvi
Jul 23, 2009 03:17 PM
1SikEagle
Apr 11, 2009 01:02 PM
