Unknown clutch issue...
Old May 15, 2009 | 04:59 PM
Edul59's Avatar
Default Unknown clutch issue...
So along with my other thread about my h22 not running good i found out my car decided to give me another issue...when i try to go into first or second gear...its very hard and i have to muscle it it. however...when the gear does go in...and the clutch pedal still pressed the car seems to jerk and buck as if like i was taking out the clutch, but i am not. At a stop with the car on, the same issue occurs. while stoped and in gear with clutch pedal it feels like im about to stall it. i searched and nothing i read is posted like this.
Another thing. at a stop in i put in 3rd through 5th and dont release the clutch pedal...the jerk/buck feel comes and goes..
Ive checked the master cylinder and slave and they are fine. there is fluid in the resevior.
Ahh i love my car....what can it be?
Old May 16, 2009 | 03:35 AM
extrudelude's Avatar
Default Re: Unknown clutch issue...
Did you bleed the slave cylinder?
Old May 16, 2009 | 04:46 PM
JohnsJDMCB7's Avatar
From: Hagerstown, Maryland, United States of America
Your pressure plate might be going out
Old May 18, 2009 | 11:57 AM
Edul59's Avatar
yes i bled the whole system...any one else any ideas?
Old May 18, 2009 | 07:43 PM
93sivtec's Avatar
It sounds like its time to replace the clutch.....thats not right for sure.Could be the disc itself or the pp as before mentioned,either way buy a clutch kit and get your flywheel resurfaced.....cause its time.
Old May 19, 2009 | 08:32 AM
ArmaanOG's Avatar
replace the clutch pp and flywheel.... ebay has some good exedy/fidanza kits. thats the sign of your clutch going by bye and if you keep driving like that your gonna be stranded somewhere
Old May 19, 2009 | 07:37 PM
nuezdaman44's Avatar
yea the clutch is definitely catching the pp... if youre lucky the clutch is just getting stuck on the shaft and the transmission shaft just needs grease
Chris Miller
Mar 28, 2016 10:49 AM
Mikeyb918
Oct 31, 2012 05:55 PM
Christian_Chand
Jan 4, 2012 07:15 AM
96 EX
11
May 15, 2009 10:29 AM
92BlackSi
Oct 26, 2004 03:51 PM
