tune up..
Old Nov 4, 2006 | 11:02 PM
bboixtc's Avatar
Default tune up..
gas mileage has steadily dropped in the past two months, my 92 lude is at 95,xxx. i got my water pump, timing belt, head gasket, and valve adjustment done at 86k at honda. what's included in a tune up. i'm assuming i need one since i'm at this mileage already. i definately need a new cone filter. cause my injen one is dark as hell. but what else?
Old Nov 4, 2006 | 11:08 PM
Hawkze_2.3's Avatar
Default Re: tune up.. (bboixtc)
Full tune up can be:
-fuel filter
-air filter
-spark plugs/wires
-distributor cap/rotor
-oil/filter change
-valve adjustment
-full Seafoam treatment
Tire pressure also has a lot to do with gas milage as well as driving style.
Old Nov 4, 2006 | 11:22 PM
lude98SH's Avatar
Default Re: tune up.. (Hawkze_2.3)
The only other thing I can think of is PCV valve and clean the Throttle Body and intake manifold. IM would already to pretty clean if u run the seafoam through it though.
Old Nov 5, 2006 | 12:11 AM
bboixtc's Avatar
Default Re: tune up.. (lude98SH)
1)where can i get seafoam?
2)does it matter what spark plugs/wires? oem @ honda is fine?
3)distributor cap/rotor @ honda is good too?
4)fuel filter necessary?
5) pcv valve..
anything else included in a tune up or atleast i should be doing at this mileage interval? cause i'ma bout to do this all at once. might as well pay honda to do it for me. well my friend works there so he said he could hook me up on the parts and labor wouldnt b much since he'd be doin it.
Old Nov 5, 2006 | 03:46 AM
Duane_in_Japan's Avatar
If you or someone else is going to adjust the valves then do a running vacuum test before and after the adjustment also check the MAP voltage before and after the adjustment also, MAP reads vacuum. Give us these items when you are completly done. Did anyone mention valve cover gasket set also.
Old Nov 5, 2006 | 08:22 AM
lude98SH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bboixtc &raquo;</TD></TR><TR><TD CLASS="quote">anything else included in a tune up or atleast i should be doing at this mileage interval? cause i'ma bout to do this all at once. might as well pay honda to do it for me. well my friend works there so he said he could hook me up on the parts and labor wouldnt b much since he'd be doin it.</TD></TR></TABLE>
Maybe change the trans fluid. Thats about all i can think of. That has a 30k milage interval.
Old Nov 5, 2006 | 08:38 AM
bboixtc's Avatar
I already got a valve adjustment when i got the water pump, timing belt, and headgasket.
but what is seafoam? i've done some research and heard about putting about 1/2 in full gas tank. and you're set. i was told to put it in a week or so andbefore my tune up so that way if my spark plugs or something get clogged up w/ carbon or something they'll be replaced anyway. i dunno.
Old Nov 5, 2006 | 09:36 AM
UNLTD's Avatar
Fuel Filter, Gas treatment addictives, a lighter foot, Distributor cap & rotor, New Spark plugs and Spark plug wires, PCV Valve, O2 sensors, and change the oil.
Old Nov 5, 2006 | 10:28 AM
bboixtc's Avatar
Default Re: tune up.. (UNLTD)
o ok. so oem spark plugs & wires r fine? i have a basic setup. h23a1 i/h/e
ButtersNZ
Honda CR-V & Element
Nov 17, 2015 09:38 AM
JDM215
Nov 30, 2010 03:51 AM
bboixtc
Nov 17, 2006 07:25 PM
BoostFrenzy.com
Apr 8, 2004 08:09 AM
vtecdc2
Jul 15, 2002 06:41 AM
